Question about HP Genuine HP 95 Tri-color Inkjet Print Cartridge with Vivera Ink Printer
After refilling my HP 95 ink cartridge, the ink still reads empty
Does anybody know how to reset HP 95 ink cartridge (from the contacts) these cartridges?For Model HP officejet 6300.
Cartridge Error:on left must be replaced.
Thanks
  • CoryRay May 16, 2009
    Last time I printed with this ORIGINAL, not refilled cartridge, it showed 1/2ish full. I just tried to print a page in black and white and I get the "replace the left cartridge" error (you know the one!) I cleaned the contact points and the print heads with rubbing alchol to no avail.
SOURCE: Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Posted on Aug 23, 2008
SOURCE: kodak esp3 cartridge refilling
I contacted Oddparts.com an excellent resource for refilling and resetting equipment for ink cartridges and they can not find something to reset them with either. People we need to find a solution for this! I refilled the cartridge before it was empty and i do know that the oddparts ink WJ - 1010 will work in them... but of course, the ink reset issue..... I will keep trying or blast! i will return the junk!
Posted on Feb 17, 2009
  • 744 Answers
SOURCE: refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
Posted on May 16, 2009
mstipps
  • 16 Answers
For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
Good Luck~~! mstipps@yahoo.com
Posted on Jul 07, 2009
  • 123 Answers
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Posted on Oct 21, 2009
ATASCO HP OFFICEJET J4585
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
Hp officejet j4580 flashing "incompatible
hello
you must purchase original ink cartridges -- not all compatible cartridges are built the same..
i would suggest buying authentica , from HP dealer or reseller
go to www.compluscominc.com, they will help you for sure and let you kno what to buy and how much
CC653AN icon_x.gif Contact Reseller
HP 901 Black Officejet Ink Cartridge - Prints approximately 200 pages (North America)
RoHS: Modified
CC654AN icon_x.gif Contact Reseller
HP 901XL Black Officejet Ink Cartridge - Prints approximately 700 pages (North America)
RoHS: Modified
CC656-30001 icon_x.gif Contact Reseller
HP 901 Tri-Color Officejet Ink Cartridge - Prints approximately 360 pages
RoHS: Modified
please send me 4 thumbs up
Aug 12, 2011 | Office Equipment & Supplies
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
"incompatible ink cartridge"
Printer needs to be reset:
1. Power OFF printer
2. UN-plug power cord at wall/surge protector
3. Turn ON printer (w/o power cord plugged in)
4. Plug in power cord
5. Turn ON printer
(This will reset the printer)
Sep 01, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
My hp officejet j4580 says incompatible black ink cartridge
I've been in print cartridge hell since I bought a J4580.
I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
  • Make sure your print cartridges are installed.
  • Unplug the machine, wait 20 seconds
  • Press and hold the # and 3 keys
  • Plug the machine back in
  • You'll see a reset message on the machine, release the # and 3 keys
  • Follow the prompts to set the language and location
Cross your fingers, hopefully your printer will print now!
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP J8750 Cartridge error
I had this "Cartridge error" problem on my HP J5780 printer. Replaced the cartridge, but still got the same error. Then removed the cartridge and used a cotton swab with a little denatured alcohol, and gently and carefully cleaned the contacts in the printer. Followed this with a dry swab to be sure no alcohol left. Replaced the original cartridge, and have been using it for a week now with no more error message.
Casey K.
Nov 07, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Genuine HP 95 Tri-color Inkjet Print Cartridge with Vivera Ink Printer Logo
513 people viewed this question
Ben Johnson
