Question about Newco NWC110410 Coffee Maker
Water is over flowing pots of coffee
Too much water being dispensed.
  • donnac975 Dec 18, 2008
    It is a newco NWC110410
  • 5 Answers
SOURCE: does not brew a full pot of coffee
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Posted on May 23, 2008
dutchman05
  • 487 Answers
SOURCE: coffee is not flowing thru system
you anti leak valve or leak stop in the bottom of your filter holder is broken. You can pull it out with no problem . Leaving you with no drip stop but your coffee will go into you decanter
Posted on May 26, 2008
STR8JCKTED
  • 42 Answers
SOURCE: It fills the pot very slow - how do you clean it?
there is also some chemical to flush thriufh a cycle called C.L.R. IT IS FOR CALCIUM LIME AND RUST ALOT OF HARD WATER DEPOSITS COME IN OUR DRINKINK WATERS.THE USE DISTILLED WATER AFTER YOU ARE FINISHED AND IT WILL NOT CLOG AS FAST
Posted on Nov 12, 2008
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Posted on Mar 08, 2009
  • 35 Answers
SOURCE: Bunn VPR Series Coffee Maker
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Posted on Sep 10, 2010
I have a bunn coffee pot that i purchased at KOHLS The serving pot leaves a mess from dripping everytime i go to . please replace the serving pot. Kohls WILL NOT REPLACE TOLD ME TO CONTACT YOU.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Make sure the two pots you are using (one to pour one to brew) is the same size. Check by filling one then pour into the other. If they don't match then get a matching one.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
PS: I've noted that you don't mention the brand nor model of the server you got from Kohls so I'm guessing it might be a dispenser or even a bunn dispenser which is different from a decanter as it has a serving spout. You find these at banquet halls where it's dispensed from a small faucet. You can find similar faucets from bunn.com or most restaurant supply stores as it's a very common item. Amazon.com has them too. the part tat leaks is the rubber boot or worn spring. best to buy the whole faucet and keep the old one for parts as needed. amazon link:
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=coffee+dispenser+parts+faucet&rh=i%3Aaps%2Ck%3Acoffee+dispenser+parts+faucet
Feb 14, 2017 | Bunn Coffee Makers & Espresso Machines
CWTF15 WILL NOT STOP WATER FLOW WHEN POT IS MADE.
The coffee dispensing valve is stuck open. It may be due to Calcium deposits.
Descale the machine or manually clean the dispensing valve and the diffuser disc that unscrews to be removed. This diffuser is visible just above the coffee pot.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 16, 2014 | Bunn CWTF15
Bunn hot water heater has a slow flow of water
Try brewing a few pots of white vinegar solution, no coffee in the system.
Jan 22, 2013 | Bunn 125000024 Hot Water Dispenser 5...
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
I have water draining back into the reservoir. It has been descaled and the needle openings have been cleaned.
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 14, 2010 | Keurig B60 Coffee Maker
How can I clean my bunn vp17-2 coffe maker the water will not leave the holding tank to go to the filter
First make sure you have enough water in the machine. It holds about 2 and a half pots of water in the holding tank. If the machine sits for a week without use but is still plugged in, sometimes the water will evaporate down to the point where pouring one pot of water in, will not fill the tank back up. If you still don't get a water flow, take the brew funnel out and reach up where the water normally comes out, There is a round water dispenser about 2 inches in diameter. Unscrew it by turning countercloclwise. It has a dozen or so holes where the water come out. Be sure these holes are not stopped up. There is a small pipe fitting where you took the water dispenser off. Bunn makes a long spring like thing that fits into this hole to remove built up lime deposits. If you don't have one you can use a flexable wire like braided copper wire about 18 inches long to push through the hole and slide it back and forth until it comes out clean. If you have hard water, like well water you may be getting a lot of calcium build up in the tank. Put about a quart of vinegar in the next coffee pot and let it sit an hour. Pour water through the machine until it stops smelling like vinegar. That should solve your problems.
Oct 08, 2010 | Bunn VP17-2 Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
Sep 10, 2010 | Bunn VPR Coffee Maker
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Newco NWC110410 Coffee Maker Logo
27 people viewed this question
Top Newco Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
