Question about Philips 32PFL3403D/27 32 in. LCD TV
CF appears on display
Just one channel works, the romote control doesnt` work at all.
LCD TV is absolutly new, used just for one week...
What is wrong?
Thks!
  • 5 more comments
  • e_lasalvia Dec 21, 2008
    same problem, tv new control remote doesnt work and cF appear on pisplay, what can I do??
  • chantalk Jan 07, 2009
    Also cF in display and only manual control over tv.
  • Anonymous Jan 29, 2009
    cf on screen, only manual control
  • Anonymous Mar 14, 2009
  • Anonymous Apr 10, 2009
    cF op beeldscherm en alls is blockerd.
    Solution??
    Thank
    Aroen
  • momak1 May 09, 2009
    cF appears on display
  • tomfelder13 May 10, 2009
    cf in display
TV is in 'factory mode'. Press ‘VOLUME -' and 'CHANNEL -' buttons on the TV at the same time for 3 seconds. See also:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=52PFL3603D/27&scy=CA&slg=en#
Posted on Mar 13, 2009
    New Friend:
HELLO, THERE ARE THE LETTERS CF ON THE TV BUT IT IS ALSO LOCKED (CHILD LOCK). WHAT CAN I DO?
Posted on Apr 19, 2011
SOURCE:
My thorn 55 inch smart TV won't work when I go to the smart TV it just says no signal northing will work can you help me
make sure that you change the channels both to the right setting on your television and your romote and also replacee the batteries in the romote
Jun 07, 2015 | Televison & Video
Beko fst.nicam.fastext
LOST THE ROMOTE FOR THIS T.V. GOT A ONE FOR ROMOTE CONTROL BUD ... BUT THE ONE FOR REMOTE CONTROL IS ASKING FOR THE T.V DEVICE CODE COULD ANY 1 HELP ME OUT THERE ??
Feb 16, 2010 | Beko 324250WN 28" TV
Trying to find remote or is there another way to get all stations on this t.v without the remote
You can try to buy a samsung universal remote, buy a samsung vcr which has a tv/vcr switch, and this will let give you control of the tv and also allow you to program the channels. Because the vcr acts as a tuner.
May 11, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Mar 21, 2009 | Nikon D100 Digital Camera
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
TV is Locked
I've solved this problem by trying w/ VIZIO LCD TV Remote Control and it's working eventhough not all the buttons can be used but the common buttons such as CHANNEL, VOLUME, MUTE, PIP, MENU they all are working w/ this LG RU-23LZ21 LCD TV
Feb 15, 2008 | LG RU-23LZ21 23 in. HDTV-Ready LCD...
Switch on - Switch off! Coolpix3100
Coolpix uses SD cards, not CF. Anyway, try using the camera without memory card, only with internal memory. If it works, then replace memory card.
Oct 01, 2007 | Nikon Coolpix 3200 Digital Camera
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 32PFL3403D/27 32 in. LCD TV Logo
2,470 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
