Question about Umax Office Equipment & Supplies
My UMAX PowerLook 1100 does not start and gives the message CANNOT CALIBRATE SCANNER. I have dowloded the latest software from Silverfast Ai v.6.6 and thought that would fix the problem as I run a MacPro with OSX 10.5.5
  • securit Dec 18, 2008
    Well, thanks. The lamp does light and the scanner starts up with trying to shift the lamp but then stops and flashes the error message and by the way- the lock is open! The power is there and the firwire works or it wouldn't start on a cycle.
    Gunter
    I have loaded the new Silverfast 6.6 which is just released for OSX10.5.5
    Gunter
  • Umax Master
  • 1,879 Answers
Which one do you have ?
SilverFast Ai 6.0 for UMAX Scanners (For both Win and Mac)
or
SilverFast SE 6.6 for UMAX Scanner (both Win/Mac)
and how is the scanner connected to the mac?
MAKE YOUR SCSI SCANNER WORK WITH USB IN OS 10.2~10.4.9
Your UMAX SCSI scanner will work with USB connection with SilverFastsoftware in OS X (10.2.1~10.4.x) if you have a USB-to-SCSI adapter.You can purchase this USB solution kit from us at www.umax.comAll the USB solution kits from umax.com have been fully tested and work with Mac OS10.2~10.4.9.
Installation:
1. Install the SilverFast software in the computer.
2. Shutdown the computer.
3. Connect the SCSI end of "USB to Ultra SCSI Adapter Set" to the scanner.
4. Plug in the power cord to "USB to Ultra SCSI Adapter Set".
5. Turn on the scanner and wait for it until the two LED lights are in green solid mode.
6. Connect the USB end from "USB to Ultra SCSI Adapter Set" to the computer's USB port.
7. Turn on the computer and start the SilverFast application.
Posted on Dec 18, 2008
  • 679 Answers
Check all of your connections, and the USB into the machine. It should at least start. If there is no power, it may have just burnt out the lamp. sorry I couldn't be more helpful but if it dosen't go on it is not a software problem, good luck, Gym
  • George Bill
    George Bill Dec 18, 2008
    Ok lets try this, delete it from the device manager, as long as you have the disks for it . Once you restart it will ask you for the software for the "new hardware", just choose install from ****, if it ain't working anyhow, it can't hurt, sometimes it may loose the irq, and needs a little nudge, good luch Gym
    Brigadier General:
  • 5,158 Answers
According to the website that software is not downloadable and you would need to buy the cd.... be that as it may they only have version 6 available for no higher then 10.3 mac o/s... where did you get the software if i may ask
Robert
  • 1 more comment
  • Roberta Smith
    Roberta Smith Dec 18, 2008
    did you download the copy utility for mac ?
    http://umax.com/download/index.jsp?model...
    Robert
  • Roberta Smith
    and there is this patch as well
    http://umax.com/support/knowledge/search...
  • Roberta Smith
    also and it is often overlooked... have you unlocked the scanner ?.. the look is under the lid on the right hand side near the rear of the scanner.
Magicscan not working with umax scanner II .
Magician 4.5 is available at UMAX Official Site.I recommend that you visit Umax site and download the latest available drivers/software and install them. Also, there is a registry fix available, which may solve the issue.
Good Luck!
Hope this helps!
CreativeTECH
Dec 22, 2010 | Umax PowerLook 1100 Flatbed Scanner
All scans with Umax Powerlook III are totally black around the edges with strange color bars where the images should be. This is using Umax Silverfast 6.0 software on a Mac running OS 10.4.11
sounds like the scanner is dead. only way to be sure that its not a software issue is to try that scanner on another machine. if you get the same issue on seperate machines, its a good bet that scanner is toast. Fortunately, you can usually go to the Salvation Army or Good will, and get a used scanner for 15 bucks, all you need is downloaded drivers and appropriate cables.
Jul 21, 2009 | Umax Astra 2100U Flatbed Scanner
Ihave a Umax Power Look 1100 with 2
Hello, yes you will just need a firewire 400 (6 pin) to 800 (9 pin) cable as the new iMac no longer supports the 6 pin connector.
Jun 27, 2009 | Umax PowerLook 1100 Flatbed Scanner
Trying to connect Umax PL 2100XL (SCSI) to G4 - scanner not found
I just told someone else this solution...KILL the SCSI junk...I had nothing but trouble with it with my Mac....I got a Ratoc Firewire to UltraSCSI Converter...to solve the regular SCSI to ultra SCSI problem...I also bought an adapter....It works great...no need for a SCSI card...or a driver...you just plug directly into your firewire port! If anyone can help me with my TA adapter startup problem...I'll be thrilled! Carole
Mar 23, 2009 | Umax PowerLook III Prepress Flatbed...
Powerlook Umax 1100 Flatbed scanner & Mac 10.5.5 Driver's..?
Looks like they'll let you buy Silverfast SE for just ... $49. Wow. Expensive price for just a driver.
On the premise you may not need the Silverfast software per se, just the driver, you may be able to, after investigating the legality, try a demo version of a Silverfast product and see if you can keep the driver itself after you get uninstall Silverfast.
http://www.silverfast.com/get_demo/en.html
Dec 07, 2008 | Umax PowerLook 1100 Flatbed Scanner
Umax Powerlook 1100 with Mac OS 10.5?
Long ago I had to resort to a third party scanning software, called VueScan from Hamrick Software. Works just fine now.
Dec 01, 2008 | Umax PowerLook 1100 Flatbed Scanner
Umax powerlook III scanner not working with latest mac system sof
Your OS is not compatible. Period. Either go back to what worked for you or get a new scanner that will work in new environment.
Jun 23, 2017 | Umax PowerLook III Prepress Flatbed...
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
