Question about Car Audio & Video
Jensen vm9411 has no sound from radio hookups put rca wires have sound
  • garywelch964 Dec 18, 2008
    yes i can get sound from the rca outputs and an external amp an subs but i cant get any sound through the factory radio speakers checked all connections and colors 6 times and there is no factory amp in the vehicle
  • Guy May 11, 2010
    What do you mean by radio hookups? Did you say the RCA outputs are working?
  • 27 Answers
If the previous radio played all the speakers and the new one wont either:
1. You have not hooked the speakers up right.
2. All your speakers are blown.
3. There is a factory amp, you just don't know about it.
4. The radio has blown final outputs.
5. One or more speakers or speaker wires is seeing a ground (shorted out)
First check the radio, hook up a know good test speaker directly to the speaker outputs on the radio. If it works, then take a 9volt battery and try to pop the inside speakers with it. When you touch the + & - speaker wires to the battery + &- you should hear a pop at the speaker. If you do you don't have an amp. If you don't you might have an amp or the wire going to the speaker is dead or shorted out. It is unlikely that all four speakers would be bad or have bad wires. If none of them will pop you need to turn on the factory amp. Then they will play. If only one speaker wont pop then that is the bad speaker. If they all pop then you have a bad speaker or wire.
Posted on Dec 18, 2008
Tv has sound but no picture
Should be the same bypass. Do you get any message when you put it on a TV station? Guess what, after Feb 17th, it won'y matter anyway unless you're going to get a digital converter for it!
Try grounding the pink brake wire and see if that does anything. As far as I remember, that bypass is for ALL video on the screen. Let me know.
Peace,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Jensen VM9411 Car Video Player
Jensen VM9411 Radio Issues
Check the antenna connections on the back of the radio and on the antenna itself, it sounds like a loose connection
Nov 25, 2008 | Car Audio & Video
Just installed vm9312
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 08, 2008 | Jensen's VM9312 Car DVD Player
Jensen Model Vm9411
take it to a repair shop to clean the lazer probably is dirty.
Jul 03, 2008 | Jensen VM9411 Car Video Player
No harness
try ebay or jensen.com
Jun 26, 2008 | Jensen VM9411 Car Video Player
Jensen model#vm9411
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the blue one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Feb 25, 2008 | Jensen VM9411 Car Video Player
How do you install the dvd portion so i can view movies
I have Jensen VM9411 I put code 1264 and disable my remote control now is not working and my screen is not working
Aug 22, 2007 | Jensen VM9411 Car Video Player
Jensen vm9411
if you are sing the single blue you need to slit that with a male to two females then hook up both L and R to the female connectors. Hope this helps
Mar 24, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9411 no sound
Check to make sure your vehicle does not have a factory amplifier. If you used a fit kit with wiring harness. try looking at how many wires were used in the factory unit compared to haw many you are using now. see if there are extra wires in the vehicle. If there is extra wires it is a pretty good clue the vehicle has an amplifier and will have to be rewired.
Sep 01, 2006 | Jensen VM9411 Car Video Player
Car Audio & Video Logo
164 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
