Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag dishwasher will not clean the cleaner does not dissolve i added the jet dry ...but i am still having problems thanks you Kerrie Hailey
  • 1 more comment
  • tiny10 Feb 25, 2008
    Detergent does not dissolve.
  • wndnice Aug 26, 2008
    my dishes are not getting clean and i have tried the gel and the powder and they are not dissolving.
  • steve wuthrich Sep 01, 2008
    detergent is not disolving, how do you know how to set water temp?? What would be causing dishes not to get clean??
    Problem Solver:
  • 3 Answers
Is your hot water set at 140? You also might have hard water, try using the Gel tablets. Good Luck
Posted on Mar 28, 2007
In my GE dishwasher, the jet-dry in the dispenser turned brown. I emptied it all out and refilled it with clean jet-dry, but a few weeks later it was brown again. I guess somehow dirty water is getting...
Had the same problem, opened up the dishwasher, pulled out the jet dry container and found some kind of nasty growth in it. I honestly have no idea what it is, so of course I took a picture, and then threw the whole thing away._1813.jpg
Jul 17, 2011 | Maytag Dishwasher
We have put jet dry and changed soaps but it always leaves a white film on the dishes! No other appliances have problems with this in the house.
Thanks for your question. You may have a couple of problems, first if you are using jet dry it is a surfactant. Which means that it places a small amount of a chemical on you dishes to keep them from spotting. If your dishwasher is releasing to much this will cause a white coating on dishes. In the loading area for you jet dry or liquid spot rinse there should be a knob that is marked from 1-5 or so. First turn this dial all the way down to 1. This will reduce the amount of jet dry released. Then monitor the amount of jet dry that you are going through. You should be able to get about 60 loads from a small bottle of jet dry. The other problem may be that you have washed a item that was not dishwasher safe, like a plastic bowl or such. Some of these items will leech the pigment into your dishwasher and then onto you dishes.
I might suggest that you purchase some dishwasher cleaner from you local Store. Walmart and most box stores carry this in the same section that you purchase your detergent. You will need to empty the dishwasher, following the instructions on the cleaner insert into your dishwasher. Then run it through a complete cycle. After attempting these items please let me know if you still have an issue, but I am almost certain that you will have corrected the problem. Thanks D.R. Wilkins
Nov 05, 2010 | Dishwashers
I have a Maytag dishwasher. I use Cascade and jet
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 15, 2010 | Maytag Dishwashers
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Water is plenty hot,use rinse liquid
It is common thing the inside of a dishwasher is very nasty even though it cleans you dishes it is best to run a dishwasher cleaner through the unit ever other month I do my ones a mouth jet dry makes a good cleaner it is sold right beside the rinse aid
Apr 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Soap is in the dispenser after dishwasher has been run
You need to clean your particle screen under the heating element. It is found at the bottom center of the washer under the heating coil. It is usually a plastic mesh screen and sometimes are removable. This needs to be cleaned really good about every 2 months. This will stop the problem with the suds. Good Luck This Should Help!
By the way I see that you soap won't dissolve this is not because of water temperature it is that the jets in the washer arm are clogged. You need to clean these one by one with a small cleaning device and brush. When these clog the jets of water don't come out with any force they just trickle. Clean the jets(on the arm that spins at the top and bottom of the washer and your screen and it will be like having a brand new washer.
Nov 23, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag dishwasher DWU7560AAM
Check your water spray bars. I'll bet they are plugged with calcium or something.
Oct 13, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Sep 17, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
113 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
