Question about Electrical Supplies
I have a 7kW generac that is 2 years old running on LP. The last couple months it has been stuborn about starting and sometimes not starting at all. When it does start it runs rough for a few seconds before smoothing out. What do I need to look for as to what the problem might be?
Check the rubber boot for the carb. I had the same problem and found that the boot was cracked. I replaced it and now it runs fine.
Posted on Apr 21, 2009
Check and see if the "bellows" between the air filter and the engine is cracked. If it is, there is no way that the engine will run correctly. They are very particular about their fuel-to-air ratio.
Posted on Feb 05, 2009
90 % of the time this problem is caused by a bad bellows (a rubber part) that is between the air filter box and carburetor mixer.
Posted on Jan 12, 2009
  • 3 Answers
Vapor or water build up in the lines sounds like.
Posted on Dec 19, 2008
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
I have a natural gas generac 8kw it was running fine now it will not run found that out after the last power outage pull the plug looks good found that it will not spark at the plug
How old is it???? Does it have a read out that tells you what's wrong?????When is the last time you did a maintaince tune up on it???? Mine is fueled by propane and I changed the oil and plugs and it's been fine since....Sometimes it's the starter/ignition..I would do a complete tuneup first, then clear codes, then try starting it up manually....If that works put it back on auto..Good Luck
Mar 01, 2015 | Generac 13,000 Watt / 13,000 Watt Home...
On our 20 generac a notice came up tat it needed a oiland filter chnge we did thisbut the message is still there hodo we get his message off andmke thhe light on the side go off thanks
The yellow LED is a maintenance reminder light. To reset a maintenance reminder, press the Enter key on the control panel. The reminders will be displayed at the following intervals.
"Inspect Battery" 1 Year
"Change Oil & Filter" 200 hours or 2 years, 100 hours or 2 years on 20kW models
"Inspect Air Filter" 220 Hours or 2 years
"Change Air Filter" 200 Hours Or 2 years
"Inspect Spark Plugs" 220 Hours or 2 years
"Change spark Plugs" 400 hours or 10 years
Here are a couple of links
5875 Resetting maintenance reminder light question Ziller Electric Inc...
Dec 31, 2014 | Generac Standby Generator - Residential -...
I have a 12kw lp gas genwrator that starts and runs for about ten seconds and then shuts down.after maybe 25 tries doing this the generator will stay running and then i try and start it again and it will...
These type of gens have a low oil shutoff. Check the oil. Always have spare spark plugs, a cheap fix. My gen always wanted a new plug every year. Look to see if it has a fuel filter.
Sep 24, 2011 | Generac 13,000 Watt / 13,000 Watt Home...
No lights are lit on my Nexus Remote monitor for my Generac standby generator. The generator is working - just went through the testing cycle. Batteries are less than 6 months old. Maybe I need to...
batteries only last about 3 months on these units. make sure you are within 20 ft of the generator and put in new batteries. The green light will blink is a minute or so.
Apr 23, 2011 | Generac Power Systems Generac 5928 Nexus...
Generac 7KW, Model 005251, 3 yrs old. Natural gas pressure measured 6" WC at generator when installed. When installed, dealer had to turn fuel regulator screw all the way left to get engine to start. Has...
check pressure of the fuel line running in to the regulator it sounds like you have not enough gas coming in and the if it is good was the screw reset after the bellows was replaced?.
ether way it sounds like it is starving for fuel. hope this helps
Aug 31, 2010 | Electrical Supplies
Small 7kw Generac has always sounded rough over the three years we've had it. Oil and plug are fine but lately, after warmup, engine seems to misfire and eventually shuts off during the normal weekly test...
If the generator is out of warranty, you can try spraying a short shot of ether into the intake of the generator as it is running rough. If the engine smoothes out for a few seconds, and returns back to original state, then it is likely running lean. Check the gas regulator (this is LP or natural gas I am assuming since it is standby), the vent may be clogged on the bottom of it.
Feb 11, 2010 | Generac Guardian 100 Amp Transfer Switch...
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
Electrical Supplies Logo
576 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
