Question about Samsung J750 Triband Black Unlocked 3G Phone
Sound settings How do I set the sound setting so that the phone does not make any noises when i press buttons on the phone? Please help, the phone sounds like a gambling machine
On the side of the phone there is a volume button, press it down until on the screen the picture says mute
Posted on Dec 20, 2008
I just want to stop the keys making a noise when I text
Hi there!
If you're hearing a noise or a tone whenever you text then ill be advising you to check the tone settings on your phone.It might be that the KEYPAD TONE in your phone is enabled.
If you want to adjust the volume of youe keypad tone then you can just go to SETTINGS.And after that please go to TONES/TONE SETTINGS and kindly look for KEYPAD TONE.You can lower down or turn off the volume of the keypad tone on that option. If you have another kind of phone then you can try looking for small buttons on the side of the phone. You can press the "Down" button to lower the key volume. Please press it repeatedly to continue lowering the volume. Press "Up" button if you decide to turn the key tones back on.
THANKS graham569!
Apr 20, 2011 | Cell Phones
My phone is showing an error message "3d010017"
hi , To fix the error , please reinitialize the software of ur mobile . i will give u the step
    1. While in standby mode, press the left soft key for Menu
    2. Select Settings (9)
    3. Select Reset Settings (8)
    4. Press the OK button to check the box(es) for the following:
      • All: Phone, Display, and Sound settings will be reset to the default values
      • Phone settings: Only the Phone settings will be reset to the default values
      • Display settings: Only the Display settings will be reset to the default values
      • Sound settings: Only the Sound settings will be reset to the default values
    5. Press the left soft key for Reset
    6. Press the left soft key for Yes to reset the handset
    7. Enter the password, using the keypad, default password is "00000000"
    8. Press the left soft key for OK to reset the handset
    For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 15, 2010 | Samsung SGH-t219 Cellular Phone
How can I stop the bleep tone when I am creatng a text message? Do I have to put the phone on silent mode every time?
You can adjust the volume and change the sound it makes. To adjust the volume, press the menu button, then go to "Settings & Tools". Under Settings & Tools, select "Sounds Settings" (it should be #4). Then select "Keypad Volume" (should also be #4). If you want the noise completely gone, scroll down until it says "off" and press ok. If you were talking about something else, let me know. Hope this helps!
Aug 11, 2010 | Samsung Cell Phones
Program Extension Name and change time on phone.
Please refer to the manual page 5-6 for how to storing caller's information names and numbers.
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Sep 23, 2009 | Panasonic KX-T7633 Corded Phone
Clock on Phone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jun 24, 2009 | Panasonic KX-T7633 Corded Phone
Alcatel mobile OT-S319 stop noise it makes when open and close ph
go to settings, then ringtones, then edit...scroll along passing call tone, message tone, power on/off tone til you get to a pic of a little yellow shell and a phone inside it - you have about 5 sound on/off options plus a SILENCE option, press ok then back back back to normal screen and the noise has gone! phew! It was driving me nuts too!
Dec 28, 2008 | Alcatel Cell Phones
How to change time
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Nov 06, 2008 | Panasonic KX-T7633 Corded Phone
Samsung a737 is the model
Here is a quick run down on that and a link to the PDF manual that will tell you everything you need to know.
This is for a Verizon Samsung u700 mobile phone.
1.From the main screen, press OK MENU, use the right navigation key to highlight SETTINGS & TOOLS and press OK.
2. PRESS (BUTTON 4ghi) SOUNDS SETTINGS.
3.Press (button 1@) CALL SOUNDS. or Press (butoon 1@) CALL RINGTONE to get new ringtones from "GET IT NOW" (GET NEW APPLICATIONS) or choose from the pre loaded ringtones.
4.Press (button 2abc) CALL VIBRATE to turn Call Vibrate On or Off.
5. Press OK to save settings
Aug 10, 2008 | Samsung SGH-E630 Cellular Phone
Samsung J750 Triband Black Unlocked 3G Phone Logo
91 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
