FixYa.com
Tags:
Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend (by 6 users)
posted by keborg on Mar 28, 2007
I have the older version of the etrex legend bought about 4 years ago. I am having problems in that it will no acquire satellites (says it is searching....). Is there a way to reset the unit so that it will acquire satellites?
Thanks,
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by stinger06, posted on Jun 07, 2008
My etrex will not acquire sattelites. Attempted to start with new location, but still will not track.
Comment by Coolteacherf, posted on May 15, 2008
will not lock on satellites , except one at a time.
Comment by jam2008, posted on Jan 01, 2008
I have an Etrex Legend and have also just found, after 3 years use, that I can't get a satellite fix. The satellite screen shows lots of satellites but no fixes (when they go black) so the GPSr doesn't work out where it is - any idea what the problem is?
Comment by groomsbs, posted on Dec 21, 2007
Can power up my Vista, shows satellites, and coordinates. cannot navigate away from the page or power it down. have to remove the batteries to shut it off. keeps going back to the same spot, and cannot get out of the satellite aquisition page.
Help
Comment by mccann, posted on Nov 11, 2007
My Etrex Vista says its locating satellites and will not go any farther. It obviously sees the satellites as it will show them on the satellite screen. There are no other problems. I updated the software over the internet hoping for a fix but no luck
Mike
Best Solution
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had a similar problem. The antennae had become detached and had to be sent for repair. Since the repair it's working perfectly.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 23, 2007
Helpful (85)
muskypro
Rating: 85%, 2 votes
If it hasn't been used in a long time it could take up to 30 minutes to get positioning. Get a clear view of the sky and let it set at least 30 minutes. If that doesn't work antennae connection is bad. Its not a software issue.
Can you Help with these GPS Devices problems?
garmin eTrex
Hi you experts, I've got a... Answer This...
Garmin eTrex legend Joystick...
Hi, I have a Garmin eTrex... Answer This...
Unit decides to display a thin...
You have to pull the batteries... Answer This...
hello
a guy give me a totom gps but... Answer This...
interfacing
I can not get my computer and... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
