Question about Philips PSS110/17 MP3 Player
I have a philips mp3 player that has been working fine then all of a sudden this morning it wouldn't do anything at all.it flashes between the go gear screen and a synchronizing screen and if you hit the menu jey it will run through all these test, the only test that didn't pass was TMPT2. customer service was NO HELP!
  • 8,596 Answers
The reason that customer service was no help is because your mp3 player has a hardware problem - there is no such thing as a repair service for a problem of that magnitude. The only way to get repair parts is to buy a broken mp3 player of your same model. The PSS110 is an obsolete piece of junk, and it would cost you far more to repair it than to buy a new mp3 player. Just to rule out any software-related possibilities, you can try the following troubleshooting, along with any FAQ's on Philips website, although I doubt they will help:
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
My mp3 player has been used since april of 2010 and after awile it was accidently stepped on the screen had cracked all you could see was a white blur with colors and the crack shown but it was cracked...
Dear Consumer,
We regret and apologies for the inconvenience caused to you.
We request you to kindly share your contact details with us or contact us on below mentioned contact details.
Thanks & Regards,
Philips Consumer Care, India
1800-102-2929 1860-180-1111
May 16, 2011 | Philips GOGEAR SA6045 MP3 Player
Display on mp3 player shows "Magnavox" and then shuts off
MP3 players are so cheap nowadays, so Id recommend getting a new one instead.
Aug 09, 2009 | Toshiba gigabeat MES60VK Digital Media...
Mp3 player not starting.
reset is the best way from uu can do.... may helppp
Jul 29, 2009 | Philips SA3125\02 MP3 Player
Mp3 won't charge or turn on and computer won't recognize it
the mp3 player might be going bad, might have to get a new one
Apr 22, 2009 | Philips GoGear HDD075/17 MP3 Player
Philils go gear mp3 player
My Philips go gear is not working.how to repair
Jan 21, 2009 | Philips GoGear HDD6330 MP3 Player
Philips GoGear SA6025/97 Unknown Songs.
philips go gear model no:-sa6025/97 required driver.
my problem go gear not show my pc & other pc
Jan 08, 2008 | Philips SA6025 Digital Media Player
Mp3 will not come on
do a soft reset by pressing the on/off switch down and the volume + button at the same time, if that does not work try taking out the battery for the night, I just resently had the same problem and that is what I did and it has been working fine since...GL!
Dec 25, 2007 | Philips GoGear HDD6330 MP3 Player
Problem with stupid MP3 player
I had this very same problem. To fix this problem you have to re-flash your RCA MP3 player with the following file: http://download.rca.com/download/RD1022_... My RCA Model RD 1072a as worked fine since flashing the player with this file.
Apr 03, 2007 | RCA Lyra RD1072 MP3 Player
Philips PSS110/17 MP3 Player Logo
99 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
