Question about Canon P23-DH Calculator
Loading paper I cannot figure out how to load paper in my calculator. It has been a long time since I used it.
  • 4 more comments
  • Anonymous Nov 18, 2007
    paper will not advance
  • Anonymous Dec 03, 2007
    where do you insert paper
  • dee113078 Dec 15, 2007
    I cant figure out how to feed the paper in the machine.
  • Anonymous Jun 03, 2008
    I'm trying to load paper into my Sharp el-1750v adding calculator. I can not find my directions.
  • rubynherblBU Aug 10, 2008
    Can't get paper to load. Need specific instructions...ie. where to
    insert paper and what to press.Have tried slot in back, cutting paper
    straight and inserting paper where I thought it comes out on top.
    Please help.
  • Game57 Oct 21, 2008
    I'm having problems getting the paper to load by pressing feed. I'll try your solutions. Thank you
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Posted on May 18, 2007
The easiest way to load the paper is to cut away a corner before you feed it (advise given to me from an accountant) then put the paper in the slot and press FEED. VOILA!
Posted on Apr 12, 2008
    New Friend:
I was having the same problem. I was trying however to put the paper into the top. Go all the way into the back like someone else said. Where you plug the charger. There is a slot there that the paper feeds into. Have the calculator set on print and the paper started into that slot.
Posted on Dec 05, 2012
The horizontal slot is under the silver in a "lip" of the dark gray area. Also I had to press a number sign after inserting the paper in the slot because the feed key wasn't catching the paper. After all that it worked perfectly!
Posted on Jul 02, 2007
  • Candice Robertson Feb 02, 2014
    Thank you soooo much. I could not fiqure out how to put the paper in. Thanks. Your description was perfect!
The solution # 2 is the one that I use, and Its work fine for me
Posted on Nov 14, 2007
    New Friend:
Thank you all for the help!
I have been troubled for hours.
Posted on May 19, 2017
I have tried all of the above. I don't think that the pickup rollers are working.
Bummer! What is a boy to do?
Posted on Sep 30, 2012
I was having the exact same problem with the Sharp EL-1750V...This is how i solved my problem:
Theres a thin "slot" in the back near the cord input. i actually used a heaviver piece of paper to feed through the slot. Example:" cut an unpeeled white sticker label with the back still on it"..i feed it through and once it went through and i was able to c it , i took a piece of scotch tape& attached the tip of the calculater paper.once the paper went through..wahhh laaa..i was back in business.. but regardless...this has to be thee worst manufactering everrr...i know they seen this screw up before they made the mass production..lol :)- CC
Posted on Jun 23, 2011
The trick is you have it on " Print" mode, then feed the paper into the slot and press the feed, or * button !
Posted on Oct 21, 2010
Look on the back of the calulater, you will see a little slot by where u plug in the cord. if you put the paper in there and push it in some and press feed it will pull it to where it needs to be. It is very easy to do. it took me a whille to figure out what everyone means but it really is easy,
Posted on Sep 24, 2008
I dont know if I'm just retarded or what the problem is, but I read ALL of these solutions and I had tried pretty much everything I could think of myself and nothing seems to work for me.
I think maybe what I'm thinking is the "slot" isn't, but I've tried to insert the paper into every possible thing on the calculator that could be interpreted as a slot and nothing seems to work and I've tried both the feed and * keys several times.
It just keeps printing on the same spot of the paper and it doesn't go anywhere. From above, it looks like there isn't anywhere for the paper to go TO...but I doubt that's correct.
Is there anyone who can describe the slot exactly, where it is on the calculator, what it's near, the size in comparison to other things, the colour, etc. I just can't find the freakin' thing!
Thanks for all of the solutions anyway. :/
Posted on Sep 10, 2008
Before starting you have to put it on the PRINT then feed paper
Posted on Mar 28, 2008
I had much difficulty loading the paper also. It takes some persistent 'feeding' of the paper until the FEED button catches it an pulls the paper through the paper feed slot. Be patient, you should know on the first pressing of the FEED button whether the paper has caught.
Posted on Mar 16, 2008
Pressing star key worked when paper up didn't. Thanks did have to push several times
Posted on Oct 23, 2007
Thank you Healthadvie solution #2, you are a life saver, your solution was the easiest to understand.
Posted on Aug 18, 2007
Pressing the paper advance button would not work for me. After inserting the paper into the thin slot, hit the "star" key (*) several times until the paper comes through the top slot.
Posted on Jul 31, 2007
SOURCE: How do you load paper into the printing calculator?
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
Posted on Jan 23, 2009
julzgaye
  • 3 Answers
SOURCE: loading paper
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
Posted on Feb 07, 2009
PA8558
  • 28 Answers
SOURCE: Loading paper
A lot of times, the paper will not advance into the calculator without the paper being cut STRAIGHT ACROSS. Try cutting it straight across and then try to feed it in. The rollers should be able to grab the paper at that time.
If this helps, please rate me. Thanks, Patty
Posted on Jan 04, 2008
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
SOURCE: I cant' get new paper installed on desktop calculator
There is a small **** right where the paper roll gets installed - it looks like the seam between the top and the bottom of the calculator. The paper feeds from the roll directly into this - maer sure you have a very clean edge to start with - then turn on the print function and push a button until it starts to feed through. Be patient with it but it will work.
Posted on Mar 23, 2009
Canon p1-dhv Lost manual and can't figure how to load paper roll!
http://www.usa.canon.com/app/pdf/calculator/P1-HDV_G_USA_HWB.pdf
This is for the P1-DHV-G but the paper loading process should be the same.
Feb 20, 2011 | Canon P1-DHV Calculator
Can not figure out how to load paper
Visit this link and see page-3 (Procedure for paper loading)
Good Luck and have a nice day
Rating the solution is highly appreciated.
Aug 19, 2010 | Canon P23-DHV Calculator
Need to load paper into calculator
There is a small flat area on the back of the calculator. Put the paper in this hole and press the FEED button.
May 06, 2010 | Canon P170-DH Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Oct 10, 2008 | Canon P23-DHV Calculator
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Loading paper
Jun 17, 2008 | Canon P1-DHV Calculator
Loading paper
Its probably worn out. I have been messing with mine and if it does feed it is slipping and overwrites.
May 05, 2008 | Casio HR-100TEPlus Calculator
Canon P23-DH Calculator Logo
6,999 people viewed this question
Clive
Clive
old marine
old marine
