Question about Nokia N95 Cellular Phone
My N95 blinks and goes blank
My phone goes black wen u press to select an action, there are lines on the phone, and sometime the screen turns upside down. it like the screen is pixellating.
What do i do?
    Scholar:
  • 145 Answers
There can be three possibilities:
1.You have a virus in your phone, so get an anti virus installed.
2. You are putting too much of load on your phone processor,for eg multitasking, full memory etc. , if this is the case free up the memory.
3. Phone's software(firmware) is corrupted, go to your Nokia service center and they'll repair the software installation, but in this case you'll loose all the data you had on your phone and it will be a blank phone like you just bought it
Posted on Dec 18, 2008
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
N95 black creen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Good luck.
Aug 27, 2010 | Nokia N95 Cellular Phone
N95 won't power up
To restore original settings; Press, and select Tools > Settings > General >
Factory settings. You can reset some of the settings to their originalvalues. To do this, you need the lock code. After resetting, the device may take a longer time to
power on. Documents and files are unaffected.
Sep 05, 2009 | Nokia N95 Cellular Phone
N95 blank screen every 7 secs help?
kindly re upload your software!!!
Apr 25, 2009 | Nokia N95 Cellular Phone
Not getting started
Would you mine formatting ? if not, while the phone is off, press call ( the green one) + 3 + * and turn the phone on.
Yes, you have to press 4 buttons at a time. *,3,call and the power on.
Try it. it should solve your problem.
You may miss 3/4 times...cz, it is not so easy to press all at a time correctly.
Apr 20, 2009 | Nokia N95 Cellular Phone
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
N95 internet
this is phone hardware and software problem
Sep 26, 2008 | Nokia N95 Cellular Phone
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Jun 02, 2008 | Nokia N95 Cellular Phone
N95
hi there!
i do have a nokia n95.. but my problem is that im having problems in downloading a theme as well as java games.. what should i do? can somebody help me with this?
May 23, 2008 | Nokia N95 Cellular Phone
NOKIA N95 BLANK SCREEN
It must be a connection problem, to the LCD, or the light is not working.
Can only be sorted by looking at it really.
Back to Telstra I'm afraid. If it's new let them sort it out, if it's not try a reset take the sim card out first then input this code *#7780# (Best to use this code as a last resort)
Give it time to work.
Jan 10, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
