Question about RCA D52W19 52" Rear Projection Television
Rca problem thank you for your post to my problem. i was wondering if i would need to dsicharge anything before i just took to soldering on my tv. i have a good iron and what not, just want to make sure i do not do further damage to the tv or myself. thank you very much for your time! Tony Nesbitt
  • RCA Master
  • 5,138 Answers
No your in no danger with this board!
Posted on Dec 18, 2008
RCA F27442 - Cable showing up "snowy". Found tv outside, so maybe it's shot, but wanna chk just in case. Anything other than what 'Menu' offers can help - something physically inside...
Real common problem with RCA, bad connections in tuner/ if module, Solder tuner and if module and leave shield off tuner and solder main grounds around tuner.
Aug 15, 2011 | RCA F27442 27" TV
RCA HD52W59 Turns Off
Hi, Based on your post/description, my guess is a loose connection or a cold solder problem (higher probability). Not unless you want to make another "30 mile trip", you have to find a local tech who is comfortable working with live/hot sets. The usual precaution on working with live/hot units and HV applies. This involves opening the back cover, powering the unit and with a foot long + insulated rod (I use a broken fiberglass fishing rod), poke around the inside of the TV, part/move the wires about, also press on the boards slightly. The idea is locate the loose connection or the cold solder. Soon as located, poweroff and resolder. If there is a component/board failure, the unit would not have operated intermittently. There is a big chance that the loose connection or cold solder just worsened and that cause the recent "chosen not to work". Further, the power light still turns on and you have not posted any other indications such as a beeping sound or blinking leds/lights which normally indicates failure. Hope this be of assistance/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
I also have one of thos RCA 52 inch tvs and i am having a problem with a double screen like the outline of objects on tv is not centered so it looks like two people and the color is a green and a red...
You most likely have bad convergence IC chips. These chips are located on two large metal heat sinks on the circuit board. They are not very expensive ($60-75 for the pair) but replacing them requires de-soldering the old ones from the board and soldering in new ones. If you have some soldering  experience with electronics It may be a repair you'd like to try. A shop will want $300 and up to do this job. If you'd like further advice on this post back here and I can assist you.
Dec 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 35V432T 35" TV with crunched pcb (crt itc008 2127952A)
If the tub is not broke at the neck where the crt plugs on and the pins are all still there the there is a good chance that it will still work. You realey wont know untill you try and see. some shops might have a used crt board if they have had a tv come in struck by lighting and saved the board for what parts that was still good.I know i do that a lot. Dont think I got one for a 35 inch though.
Mar 05, 2009 | RCA 35V432T 35" TV
No video on VIDEO 2...cold solder connections on video and audio inputs...resolder, but solder pad for video has no connection ...looking for a pictorial view of the PC board to insure there is a...
I just fixed this on my TV. With the small front input board removed from the tv, solderside up and the rca jacks pointing away from you begin.Looking at the board in this position locate RCA video jack. Directly in a row are 2 comparitively large solder pads. The pad furthest from the RCA jack and closest to you has a thin trace that runs from the noted pad to a solder pad on a small surface mount component marked 750. That small trace is not making contact on the solderpad that is soldered to the RCA jack. To fix it take a small metal pic or tiny flat screwdriver and scrape away some of the PC board coating right on the trace where it meets the solder pad, and place a small solder bridge on it. Thats it put it back together and watch TV. Thanks to all the members here who post solutions. Frank
Dec 01, 2008 | Sony KV-32S20 32" TV
Rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Nov 08, 2008 | RCA 27V530T 27" TV
My RCA 52 Inch has a Problem
Brandon,
Your TV uses the 259296 Flyback. You can get one at the following link and they provide step by step instructions with detailed pictures so you can easially do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
I have three
I had the same problem. Thanks to the many posts on this site I was able to deduct that it was the Fusible Link F231. (See other posts about convergence problems) Was able to purchase them at mouser.com. Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. Replaced it (needs to be re-soldered to board) and TV works like a charm!! I couldn't believe it. What a lifesaver!! Now I'm set if the fuse goes again...
Good Luck!
Jan 01, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
