Question about Apex Digital AT2708S 27" TV
No sound and picture does not fit tv screen
I have an apex tv that is giving me problems.  The picture does not fit the screen and no sound is coming out.  This is the situation for when I'm trying to watch cable or a dvd.  Is there something in the menu that would be causing this?  Cable and dvd work fine when hooked up to another tv, so the apex is the source of the problem.  Is there anything I should try?
    Top Expert:
  • Apex Digital Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ...
Posted on Jul 25, 2017
Noggin
  • 944 Answers
SOURCE: Can the cable ends be converted to fit a DVD?
You can certainly purchase a cable or an adaptor to connect the speakers to almost anything - this however is not the issue - z5300 computer speakers have an impedance of 8 ohms, whereas most home theatre systems will be set up to use speakers with an impedance of 4 Ohms or 6 ohms or 8 ohms - using the wrong type in the wrong configuration is very likely to result in damage. Also the speakers contain their own amplifier, and are designed to accept an input that has not been amplified to speaker levels before - most tv/dvd audio output will be amplified, depending on the model, so will almost certainly destroy your speakers unless you have a low amplification output on your tv/dvd. If you post back with the make and model of your tv and dvd player, hopefully i can find the necessary info to describe how you could make the connection if it is possible. Logitech says; "Logitech speakers are powered speakers and are designed to be used with a home computer. However, it is still possible to connect your speakers to many other devices. You can connect any Logitech speaker to any device that has a pre-amp mini-headphone jack. Home amplifiers will normally contain a standard ¼" headphone jack. You'll need to purchase a ¼" to 1/8th" adapter to connect your Logitech speakers to a home amplifier. Note: Under no circumstances should you connect your Logitech speaker system to an amplified output such as the rear outputs of a home amplifier. Doing so may cause damage to your Logitech speakers as well as your home amplifier." Hope this helps - please post back with details :)
Posted on Apr 19, 2007
Shuttle83
  • 1139 Answers
SOURCE: No sound
What you may have is a cold solder joint in the audio section of the TV. To find this problem you will need a schematic, and mutlimeter, and a small audio signal finder. If you have a cold solder joint look in the audio section of the TV (The schematic will help you find it). use the audio signal finder to locat the position where the sound drops out, and then use the multimeter to find if the proper voltages are on the audio output components. This troubleshooting implies that you have the bacground in electronics, if you do not have a background in electronics I would suggest that you take the set to a qualified TV repair shop.
Posted on Nov 14, 2007
SOURCE: ipaq mp3800 projector--no source found check signal cable
compaq pesario c700 audio drver for this link
Posted on Jan 06, 2009
  • 67 Answers
SOURCE: Question regarding my Apex PF2720 TV: One channel
check your close captioning settings make sure they are off you probably are accessing an unused cc chanel
Posted on Apr 14, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
Apex LD4088 no picture
The inverter is the usual suspect with that symptom. It may be hard to find a replacement inverter for an apex model. But you might be able to get one from www.tvrepairworld.com
Oct 29, 2012 | Apex Digital LD4088 LCD TV
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Apex LD3249 LCD tv.picture jumps
The tv Tuner board,that where the coalax broscast signal come in is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Jul 06, 2010 | Apex Digital LD3249 LCD TV
Apex TV AT2002 has sound and no picture.
i am not familiar with your tv but i can say that there is a micro that control most functin of your tv,have a tech check your tv for repair
Jul 12, 2009 | Televison & Video
I get sound but no picture on my apex at2402.
if there's a channel and volume display but no picture,the problem of your tv is ABL..it is a resistor value from 10K ohms up
Oct 10, 2008 | Apex Digital AT2402 24" TV
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
SOUND NO PICTURE ONLY RAINBOW
I just fixed this problem on my neighbor TV. I don't have a manual or schematic, and didn't pay any attention to the reference designators, so I will just have to describe it. The problem was a bad solder joint. Visible thermal fatigue. Looking at the main board, (didn't even need to slide the cassis out). There is a small, narrow, vertical board in the center, adjacent to the yoke connectors with a funny looking little transformer on the very top. Check the connections on that.
-John
Dec 15, 2006 | Apex Digital GB5108 51" Rear Projection...
Apex Digital AT2708S 27" TV Logo
169 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
