I probably do, but it's easier if you take it to your local hardware store or anyplace else they sell those little buss fuses. You should be able to read the rating faintly embossed on one of the metal caps. The ones I've seen in these purifiers are typically 1W (1 watt) and are often sold in little boxes of five for a few dollars.
If you have friends or relatives who do DIY (do-it-yourself) stuff, hobby electronics or car repair, you might check with them first - they are very common, and you might get it free for the asking.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks using Fixya.com,
Jon
Comments:
Jan 03, 2009
- I should add a note - - another reason I can't supply is you that FixYa prohibits us from soliciting business when we do this unless we have written permission in-advance, which I don't yet have.
That, and it would cost you more in postage for me to ship it to you than to buy it yourself.
One minor correction - the fuse would be measured in amps, not watts.
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several...
(More)
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several times but the unit always comes bak on and tell me it need normal cleaning . I cannot clear the display. I have just given the unit a thorough cleaning but the display still say perform cleaning. Nothing on the front control responds.
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine...
(More)
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine was not working.
I have two identical units and I have swapped every removeable/replaceable part including cord and...
(More)
I have two identical units and I have swapped every removeable/replaceable part including cord and new fuse and the unit will not power up
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it...
(More)
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it goes off. Do you have a solution to this problem?
