Question about Canon HV20 HDV Digital Camcorder
Dirty heads canon hv20 heads are dirty. camera won't record or play back ANY tapes. just cleaned heads with cleaning cassette. 3 times.
  • Anonymous Jan 10, 2009
    Dirty heads, won't playback (the tape runs, but the counter doesn't move and blue screen...), but i think records fine... No way to know it for sure though ^^.
    Problem Solver:
  • 12 Answers
I work for canon and when I get one this dirty I use a tape that has been recorded with used or almost used up. I let the tape rewind and fast forward all the way through. I then use a soft head cleaning tape for 25 secs. If that doesn't work then it might need an adjustment.
Posted on Jan 01, 2009
When I play tapes I recorded in my ES75 hi8 it just plays static, no pictures
Be sure you have rewound your cassette to the beginning before playing back your video. Also, be sure that the tape heads of your camcorder are clean.
Use head-cleaning tapes regularly to keep your camera in top shape.
Mar 08, 2011 | Canon ES75 Camcorder
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Canon DM-XM2 Will not record or play back
Clean Idler unit it is magnetism and clean sensor it will work
Mar 08, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Not recording
What camera are we talking about here? Have you tried resetting the camera?
J. DeRuvo
Digital Camcorder HQ
Dec 04, 2007 | Video Cameras
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
No tape icon when the tape is installed
Alot of times dirty tape heads can cause this issue. Try loading a Digital Head Cleaning Cassette into the unit, and let it clean the heads. Many times this will solve the problem. Also, make sure it's not the 'wet-type' cleaners, as this will cause damage.
For the record issue, make sure the tapes do not have the prevent erasure tabs set - this is on the bottom of the tape, and is looks like a tab that says ERASE OFF or SAVE.
Not much else that can cause this issue. Never force the tape into the unit, and never hit the unit to get it to work. If nothing works, then I would suggest taking into a service center for diagnosis.
Hope this helps some.
TWEAK A/V LAB
Jul 29, 2007 | Canon XL1S Mini DV Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Lines in replay
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. If such symptoms appear, clean the video heads with a commercially available dry cleaning cassette. If the symptoms reappear shortly after cleaning, the video cassette may be defective. Stop using the cassette. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Dirty Replay
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon HV20 HDV Digital Camcorder Logo
535 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
