Question about Kenmore 22422 Top Load Washer
Kenmore 22422 washing machine leaking
My washer is leaking really bad...I'm not exactly sure the water is coming from.I tilted the machine up to get a look underneath and couldn't see where any parts were wet,so I started filling up washer to try and see where it was leaking and water started pouring out from behind the pumps and stuff(i'm a chick so I don't really know what I'm looking at) Any help would be great...Laundry,Laundry...everywhere..lol
  • 113 Answers
Your going to have to take the cabinet off to get a better look at where its coming from. I can walk you thorugh it if you want. Your best to enter a live chaf for this. Thanks Dave
Posted on Dec 18, 2008
My washing machine leaks when it's does the washing cycle
if the leak is at the frount of washer than you have a bad seal in water pump.you will nead to replace the pump.
Jan 17, 2010 | Kenmore 22422 Top Load Washer
Washer machine
Sounds like the hot water solenoid is stuck.
Feb 11, 2008 | Kenmore 22422 Top Load Washer
Machine is leaking water from somewhere?
there is a seal between the drum and transmission,more than likely thats where its leaking. also check your fill hoses and valve
Jan 09, 2010 | Kenmore 22422 Top Load Washer
Kenmore series 70 squealing and leaking water
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your pump is bad.
See the following illustrated description of how to access and check / replace the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=8eaba8b07483055c9c0f23bd2274f0a8
Dec 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore 90 series top loading washer and every time I wash clothes there is water all over the floor.
Disassemble and look for problems, there are several smaller hoses that can come off and allow leaks.
Sep 13, 2009 | Kenmore 22422 Top Load Washer
I have a Kenmore Elite Top Load 5 years old which leaks ONLY during the spin cycles. I beleive it may be water coming over the top of the tub. I need to comfirm and get instructions on the removing of the...
it is the water pump probably it only pumps out and has pressure on it when it is spinning easy to remove just pull it away from the wall a couple of feet and tilt it back lay down on the floor and it is the first thing you see next to the front panel two clips and a couple of hose clamps
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Dec 29, 2008 | Kenmore 22422 Top Load Washer
When filling up my washing machine is leaking bad.I cant tell exactly where the water is coming from.I tilted the washer up so I could look underneath and couldn't tell anything was wet,so i turned it on...
Dear Customer,
i'll provide you with some checks,which when performed would stop the leakage from your Washing Machine..
Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
mam i hope this would work out.i request you to please rate this solution if it meets your needs.Thank You
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Leaking
check your water valve at back and your water connection.if there o k it probably is your pump.
Nov 12, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
114 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
