Question about Acer Aspire 1800 Notebook
Acer LCD fault
I have an acer aspire 1800 and the screen has 2 large black bands (vertical) and some bands were the image is incorect and faded. I assume I need a replacement screen. Does anyone know whats happening? I keep reading about inverters etc. Just want to make sure its the LCD at fault before I buy a replacement. The display shows fine through an external monitor so I dont think its the graphics card. Any help would be appreciated.
  • peter ledwith Mar 29, 2007
    The screen is at fault immediately you switch it on so it cant be a driver problem and the backlight still works on the rest of the screen. The display shows fine through an external monitor so I dont think its the graphics card.
    Problem Solver:
  • 9 Answers
Hi lepter, late with this report, but you may have a vertical issue, if this is not the case, check your menu setting for wide screen feature settings, if there is none, immediately change your LCD.
Posted on Apr 19, 2007
    Novelist:
    Scholar:
  • 111 Answers
According to your issue. It is definitely the issue from your LCD. Any issue from converter will cause the display flickering or given faulty color and resoulution. But here your LCD is still displayed as normal with some horizontal or vertical lines. Those signals showed that LCD is in poor condition and replace it will solve those issues. I am positive that LCD is at fault.
Posted on Mar 30, 2007
  • 24 Answers
You are correct about the inverter, on laptops about 9 out of 10 issues with video may be caused by the inverter, however before you replace the inverter try checking for new driver updates for your video, if this fails you may try hooking up an externail monitor and see if that works ok, if it does then i would try to have the inverter replaced.
Posted on Mar 29, 2007
  • 60 Answers
Definetly not an inverter issue. you would do well to replace the screen.
SOURCE:
Vizio Model# E3D42OVX. Black vertical lines on start up except for top 2"s of screen.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 18, 2017 | Vizio Televison & Video
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
Light gray screen with vertical color bar in center
Jul 29, 2015 | Panasonic Televison & Video
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
I am getting a blue line, vertical, down the right hand side of the screen. It will fade in and go away. Don't tell me my LCD is going out. I've only had it for a year.
Hope you are still in warranty, a single colored line in an LCD or Plasma is usually a screen fault, the only other possibility would be the LCD control board, however it usually generate large stripes or bad image with half the screen, a single line, 99% is a bad screen. Call Sony, screen replacements are not economical to repair.
Crampy
Nov 29, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Acer Aspire One 10.1" vertical line down the center of the screen
To determine if you have a faulty LCD screen or a faulty video card, connect an external monitor to the laptop's video port, power up the external monitor first the the laptop. The video output should automatically switch to the external monitor. If you get a normal image then the video card is OK, and the fault is with the LCD screen.
If you still get a bad image, then the fault could be a faulty video card or video RAM. Most laptops use part of the main RAM module for video RAM, try reseating the RAM modules and or test the RAM modules. If the RAM is OK then the fault is the video card.
Apr 19, 2009 | Acer Aspire One PC Notebook
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
Vertical lines
It very well could be a easy fix, Usually the Ribbon which connects from the LCD screen to the Notebooks motherboard gets bent/torn/damaged by extensive CD movement.. A close look at the Ribbon, if reveals tears or any damages a new (10-15$) Ribbon Cable may very well be in order if not a new notebook itself.. :-)
Mar 03, 2008 | Acer Aspire 9502WSMi (AS9502WSMI) PC...
Screen
this is a lcd or lcd cable problem
Feb 26, 2008 | Acer Aspire 9502WSMi (AS9502WSMI) PC...
Acer Aspire 1800 Notebook Logo
360 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
