Washer does not fill with water
My washer does not fill with water, if I use a hose from the laundry tub and fill it manually it runs the wash/spin cycle, then I have to fill it manually again for it to run the rinse/spin cycle. Any ideas?
  • mkozaczok Dec 18, 2008
    Thanks, I already did that (replaced hoses, tried it with new screens, and without screens). One other thing to note, you know how when you pull the knob to start the washer but haven't turned the water supply on yet, the washer makes a slight buzzing sound. My washer does not make that sound, it is dead silent.
  • Washing Mach... Master
  • 8,220 Answers
One simple thing to do is remove the hoses from the machine and remove the screens. Leave them off or clean them and put them back. The screens will probably be pretty clogged. Replace the hoses . Turn the water on check for leaks and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 18, 2008
  • Dan Webster
    Dan Webster Dec 18, 2008
    The next thing you need to do is buy a water valve. They ain't but 20 bucksGVI-151 generic washing machine water valve. Easy fix
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Fills with water and does not drain
It won't drain If your washer won't drain, check these: It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.. It doesn't spin or pumpIf your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.It pumps, but the water returnsIf the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
Jan 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washer has water in the bottom of it. I pressed drain and spin it did then it filled back up with water.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 01, 2010 | Kenmore Washing Machines
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Maytag PAV2000AWW will not drain or spin in 2 of the 3 wash cycle
It won't drain
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 27, 2009 | Maytag Washing Machines
After the final spin cycle, my clothes are still wet.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 21, 2009 | Hoover HTC243 Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
