Question about Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
I have a Sony CCD TRV-608 and the tape will not eject. When you press the eject button it comes up half way, the door don't open then it goes back down showing codes 31:20 then 31:22. My tape has been stuck in there for months.........
  • wolfpak24 Dec 19, 2008
    You guys are great!!!!!!. Went one step further, drilled a small hole in the cassete after I removed the door and the toothpicked worked like a charm. The camera is working again and the tape that's been stuck in there for months ejected...........Right on!!!!
  • 320 Answers
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
Posted on Dec 18, 2008
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Can't open door - can't eject tape
How old is your camera?
Seems it has weak capacitors in circuit.
Oct 27, 2008 | Sony Handycam CCD-F555 Camcorder
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
Hi 8 Tape Will Not Eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to eject the tape. You may be getting an error code that indicates the reels are not turning for some reason. You can assist the reels turning as the tape is ejected if you stick a small plastic pick or a toothpick into the reels to assist the reels turning and then you may be able to remove the tape.
Chris (ziraffa)
Oct 17, 2008 | Sony Handycam CCD-TRV608 Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
Sep 24, 2007 | Sony Handycam CCD-TR416 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Tape will not eject
This mceahnism is now defective and only a skilled workshop technician can do this job. If you need the service manual and parts we can help. Siva videolabs@gmail.com
Jan 03, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV608 Camcorder Logo
419 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
