Question about Car APS921 Remote Starter - Keyless Entry
REMOTE STARTER NOT WORKING COMPLETELY
FCC ID: ELVATOE PROOE4BS PRODUCT WAS WORKING BUT NOW ONLY LOCK AND UNLOCK SECURITY WORKING IT WON'T START THE CAR REMOTELY
Car was in the shop to get a windsheild replacement on Monday, the unit hasn't worked since. I don't have a manual to reset ???
Replaced battery this year (2008) in the summertime.
thanks
  • Anonymous Mar 06, 2009
    remote starter not working completely
  • 27 Answers
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Posted on Dec 18, 2008
  • Jason Foxall
    Jason Foxall Jun 19, 2016
    Thankbyou Guy. I couldn't figure mine out to save my life. "Page 2" Is exactly what I needed to read and learn. I appreciate it.
    Problem Solver:
  • 7 Answers
The antenna is normally placed on the windshield on top of the rear view mirror it was probably not put back when the window was replaced!
Posted on Dec 15, 2009
    New Friend:
Thank you Guy. "Page 2" is exactly what I needed to read and learn to get the remote start working on my Trailblazer since it was already installed when I got the truck used. I sure do appreciate. Thanks again Guy.
Posted on Jun 19, 2016
What is th safety controll switch
Posted on Nov 30, 2010
Remote starter not working elvatoe APS2K4SAW
Factory remote start or aftermarket ? What the hech is this elvatoe APS2K4SAW.If it isn't factory , get it out of there .
Feb 23, 2015 | 1997 Pontiac Sunfire
Hello, I recently bought a car which came with
yes..go have your codes read at your auto parts store ..they can reset this free
Oct 23, 2013 | 2009 Lexus ES 350
Elvatoe prooe4bs
I found this to be a battery problem in the key. Had a new battery fitted and problem fixed. The immobiliser works in very close proximity of the key and so it allows the car to start but there is not enough power in the battery to transmit to the receiver for the locks.
Jun 05, 2013 | Car APS921 Remote Starter - Keyless Entry
I just bought a car that came with two Pursuit PROOE4BS remote I can only get the remote starter to work but after the car starts2c if I enter and depress the brake2c the car will turn off Also I can27t...
if you enter the car after you used remote starter,dont depress your brake.you need to put your key(insert) into your igniton barrel
and turn it in to ON possition(dont crank the starter) now you can depress your brake to cancel the remote start.and your door lock and trunk maybe the installer didnt connect the wiring from remote starter to your car...
Feb 09, 2010 | 2004 Lexus ES 330
Lights don't blink for remote start
If you look at the unit (probably installed under the dashboard, on the drivers side) You can see the wires going into the unit... Follow the wires back and you will find that 2 of them have in-line blade style fuses, it sounds like the fuse in the parking light output wire has blown. if you find the fuse is blown, replace it and the parking lights should be on again when you remote start it.
Jan 03, 2009 | Car APS921 Remote Starter - Keyless Entry
Car APS921 Remote Starter - Keyless Entry Logo
8,424 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
