Question about Dryers
Kenmore front door latch does not hold
Front door closes but will not hold
  • Anonymous Mar 13, 2009
    put clothes in the dryer and set the appropriate time and a few minutes later the door pops open on its own
  • 179 Answers
You need a new door latch
Posted on Dec 20, 2008
My dryer door won't stay shut while drying
Dryers have a Door latch that is female and the strike that is male. When the door is closed, the door latch hooks up to the strike and keep the door closed. PLEASE inspect these items. Also, make sure that the door is loose from the screws that hold it to the body.
Dec 03, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Front loading Kenmore door will not click closed
The problem, based on the info that door will not latch, is one of two possibilities, and one you should be able to identify after reading this reply.
If the "strike" on the door is intact, that only leaves the door latch/switch assembly.
The most common latch is the Frigidaire/Electrolux number 131763245 and second the Whirlpool made 8182634. You "kenmore" is one of those two, cross reference with your model to find out which one.
Hope this helps. If so, please take a second and rate the reply provided to you here at fixya.
Thank you and good luck.
macmarkus :)
Dec 07, 2009 | Kenmore 46462 Front Load Washer
Front load washer door won't latch, close. Machine does not start
possible cause is faulty door latch also check latch on door for any raised or damaged surfaces next try pushing on door slightly if it latches and starts most likely door problem look more closely hope this helps
Nov 04, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
A lot of these errors on these front loaders can be resolved by simply unplugging the washer for 30 minutes to reset the computer. You may also attempt to manipulate the door latch by using the manual release lever to see if you can get the latching mechanism to stay open. The following link explains how to do this:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This is normally used when the door is latched with the door shut, but it still may apply in your case. If you attempt any of these preliminary checks and the latch still does not work properly, I would recommend replacing it. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hopefully you will not require any replacement parts. But, if you do, a replacement latch can be found at searspartsdirect.com or repairclinic.com. Just type in your complete model number to perform a search for parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 01, 2008 | Kenmore Elite 45986 Front Load Washer
Front load Kenmore HE3t washer wont start
If I remember correctly you have to move the door boot seal out of the way by removing the wire ring underneath to get inside to the door switch there are two screws holding in the latch on the outside
Apr 18, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite problem
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
183 people viewed this question
Top Dryers Experts
