Question about Samsung HCL4715W 47" Rear Projection Television
This tv has been a nightmare, its been down 3 times in 4 years.
Upon viewing the tv it looks as if someone is squeezing the picture inward from top to bottom, the three colors are bending and or not aligned. viewing a person's face i see 3 sets of all the facial features and 3 sets of the different colors. can anyone be so kind as to help me order the right replacement parts, thank you for yor time and expertise.
    President:
  • 3,130 Answers
The convergence board, AA95-01799G is available from http://www.samsungparts.com for about 122 bucks + shipping. You also may need to get the service manual so you can do the convergence alighnments with this set when you replace the board. You will also need the manual to perform the perfect focus alighnment on this set if you have that feature. Good Luck
Posted on Mar 28, 2007
SOURCE:
Picture is warped, colors are off.
The ITC222 and ITC222A convergence option missing repair kit should repair that issue. You can get the kit at www.tvrepairworld.com which contains the parts and the CD with instructions its 24.95
Oct 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Red gun problem phillips 60pp9202/17f
Same sort of problem here. My red looks like it's pinched in the middle and is curving inward. The whole picture looks like you should have 3-D glasses. I've heard it's a problem with a convergence chip, but I have no clue how much that will cost to have someone come fix and we live in a rural area in MO. I'm sure that will jack up the price. Mine is only about 4 years old, I wonder how much I could sell it for (as is) and buy a new TV.
Oct 27, 2008 | Philips 60PP9202 60" Rear Projection...
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
