Need a replacement charger for my gateway laptop computer
    Scholar:
  • 145 Answers
Go to your dealer and buy it. This is a Technical support site. Please ask only technical questions
Posted on Dec 18, 2008
What could be the problem with my Gateway NV59 not turning on. I have it plugged in in case there is a problem with the battery but still no power
firstly, check the laptop charger/adapter, determine if its working or now. If the charger/adapter is working, then your laptop has developed a power problem.
You need the help of a computer expert to have it fixed.
Take care.
Mar 17, 2015 | Gateway Computers & Internet
How to fix charge port yourself
Go here friend ; https://www.youtube.com/results?search_query=Gateway+W350A+charger+port
One of the videos will show you step by step to change the port. All laptops are similar method.
Aug 20, 2014 | Lifetime Gateway W350A Replacement Laptop...
I need to purchase a new charger for my Gateway CX2724 laptop. Will any charger for a Gateway laptop do, or do I need to look for one for my model specifically?
there are different voltage outputs and amperage ratings on different chargers. as long as the plug fits, and the numbers are the same, you'll be fine. I would try to get a charger meant for your unit though.
Mar 27, 2011 | Gateway CX2724 Laptop Charger...
WAS MISSING CHARGER, but was running on battery. will not charge battery or power up, no lights. Battery went dead MT6821 GATEWAY
All you need to do is be sure whu will need to replace both.
If the problem is with either the charger/battery you will need to figure that out first.
Please have the battery charged of your laptop, and try using the laptop only with the battery and without the charger, If it works fine you will have to check the charger now.
In order to check the charger, please take out the battery from the laptop, now connect your charger to the laptop and try switching on the laptop. If it does not work then your charger is faulty.
You can purchase the accessories online at various portals. I am providing one of the portal information:
http://www.laptoptraveller.com/battery-gateway-mt6821-laptop-notebook-accessories.html
Sep 01, 2010 | Gateway Computers & Internet
Gateway MX8738 power adapter problem
Does the DC jack on the laptop wiggle or feel loose?
If that's the case then eventually the jack will go bad will have to be replaced. Most computer shops charger around 60-100 for the repair.
If it's the charger itself then just replace it with an ORIGINAL from eBay.
Hope this info helps and if you need more specifics just let me know.
--RescueTechLA
Nov 29, 2009 | Gateway MX8738 Notebook
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
I dropped my laptop and now the battery will not charge.
Most likely its the DC Power Jack. Happened to me. You can find the part online by searching for "450ROG DC Jack" and then just resolder yourself or take it to a repair shop.
Jan 19, 2009 | Gateway 450ROG Notebook
GATEWAY LAPTOPS NOT CHARGING...WE NEED TO GET FILE COMPLAINTS WITH BOTH BBB AND GATEWAY AND THEN SUE THEM IF NOTHING HAPPENS...
I was told by the computer repair company the connection is arching back and shorting out the chargers. To have a connection replaced would be $150 so that is what we are going to do. We have gone through 4 chargers on our gateway also.
Jan 12, 2009 | Gateway MX8711 Notebook
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
