Power Supply Problem with -5V
I have 5 years old computer P4,D845 GLVA-motherboard.My poblem is,what PS stop to work.I both new power supply,but in new Power Supply main power connector- no white wire (-5V).A if I can to use this PS for my computer? If yes, tell me,please,how?
  • Anonymous Mar 13, 2014
    yes
    Sergeant:
  • 291 Answers
Get the original power supply for that mother board, don't save money and don't fool around with the computer like that!!
Posted on Dec 18, 2008
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
I have an old Hp Pavillion 505n desktop computer. Has been working fine for years. Awhile ago it would not turn on at all. The disk drive lite would flash on and off a few times then nothing. I removed the...
That 4 pin plug generally supplies power to the processor. It depends on the processor type. Unfortunately the next step in troubleshooting is to replace the motherboard or the processor and there really isn't a good way to know which one first.
Jul 29, 2011 | Computers & Internet
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
SCHEMATIK DIAGRAM FOR POWER SUPPLI
I would also have liked to have had a schematic diagram for my ECHOSTAR 450w ATX power supply.
Not having one though, I have replaced two capacitors (one with a bulging top) and another with a leaking top, three rectifiers (two shorted and the third had a cracked case), and have ordered transistor Q1 (also shorted). Will also need to repair trace damage on the bottom of the circuit board. Other components check out OK so I hope it will be working again after the transistor arrives Monday. I need the -5v this one supplies to get my old computer running so I can retrieve last year's tax info.
Jan 17, 2010 | Echo Star 450W 450 Watts ATX Power Supply,...
The unit can't work properly. the purple cable for 5v is ok and also the green one for ps on.but the others are spoiled out, incuding the blower.
There is a partial damage of your power supply. Rather
than troubleshooting the defect., It is advised to buy a
replacement. Troubleshooting it will be expensive than
buying. Hope this helps.
Dec 09, 2009 | Kingwin Inc. Kingwin Divine KWI-450WAS...
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Desktop won't start.
Try to replace the power supply with another known working power supply from another P4 desktop and then reconnect your wires from the front panel led lights, changing them around until they are in the correct position. I had an almost similar problem and I did the above, it is working now. All the best ! sirjohn
Oct 13, 2008 | Intel Desktop Board D845WN Motherboard
Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
MSI kt4v minus 5v (-5v)
replace the mother board capacitor its 1500uf / 6.3 v
May 08, 2008 | MSI KT4V (MS-6712) Motherboard
Computers & Internet Logo
345 people viewed this question
David Payne
David Payne
