Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZJD 125 on a timer switch
I have a timer (Time Guard - TS800) which is rated 13amp resitive (3kW). I want to use it to control when the washing machine switches on (during an off-peak electricity supply period). Not sure how much the Zanussi draws but it comes fitted with a 13 amp fuse plug.
I have zanussi washer-dryer ZJD 125. Now my dryer does not work. It runs for about 2/3 minutes and then stops.
Posted on May 09, 2010
  • Zanussi Master
  • 3,463 Answers
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
Posted on Dec 18, 2008
Intermatic t1202T 240v dual pool timer. Main pump continues to run and manual overide will not shut it off. Changed the timer mechanisim and same thing. Disconnected the Freeze control and it wil
Maybe the PF1202?
Probably just the freeze thermostat and not the relay.
Disconnect freeze thermostat wires from relay... and substitute a single-pole switch.
Be careful... power is ON
Do not leave the single-pole switch connected since 15 amp rating of typical switch is less than amp rating for 40 amp pool centers
Jun 01, 2014 | Intermatic & Indoor/Outdoor Rain Tight...
Have just purchased a hotpoint openspace pyrolytic oven. It has a standard 3 core cable on it stating it is fitted with a sealed unit plug. There is no plug and wires have been bared. Is this normal. Is it...
Is this unit new?? Are you in the EU (EU regulations say appliances MUST be fitted with a plug) If it IS new, I would be talking to the supplier!
However, to address your question If it has a standard 3 core cable fitted, then it almost certainly should have a plug on it!
To reassure yourself, just use the simple formula of Watts divided by volts = amps
I'm presuming that you are in the UK (240 volt supply) and the oven is under 3KW (3000 watts)
This being the case 3000 watts divided by 240 volts = 12.5 amps, so you are OK with a 13 amp plug. Anything above a 3KW oven in the UK should have something meatier than a 13amp plug on it.
Of course, there is nothing to STOP you wiring it to a 45 amp outlet, but the fuse rating for the appliance should be matched to its maximum consumption to protect from faults failing to blow a fuse in a timely manner.
Jul 19, 2011 | Hotpoint Ovens
I am going to install my new mytag oven MEW7530WDS01, can you tell me the Amp. protection required for this oven? it is a 220V
If it is just a single oven then a 13amp fuse is all that is required for the oven.
If you are unsure, then check the rating plate.
If the total amperage does not exceed 3kw, then it is safe to use it with a 13amp fuse., Anymore than 3kw, then it should be hard wired, with a minimum 30 amp fuse for protection.
Feb 12, 2011 | Maytag MEW7530WDS Stainless Steel Electric...
Hard wired or plug in
if i bought a single oven with a three wire cable coming out the back with no plug, which i know is meant to be hard wired, are you saying i could fit a plug to this and plug it into a normal 13amp socket, reason i ask i ahve an oven which has packed in and it plugs into the wall at the back, if i fitted a plug onto the cable from a single oven below 3kw then are you saying i can do this?
Jan 20, 2010 | Ariston Technologies Ovens
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 16, 2009 | Washing Machines
Dryer trips the fuse box
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Plug amp
Yes it should be safe to use a 13 amp fuse.
The convention with fuses is up to 720 watts a 3 amp fuse should be used and above 720 watts a 13 amp fuse should be used.
To be precise you need to know the exact wattage of the kettle.
Sometimes maufacturers will fit 5 amp fuses but these are only good for a power rating of 1200 watts maximum (at 240 volts).
So as your kettle is rated at more than 1200 watts it needs a 13 amp fuse.
Hope this is a FixYa.
Oct 20, 2008 | Breville SK85XL Nova Cordless Electric...
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
160 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
