Question about Samsung SRP 350 Thermal Printer
SRP-350 barcode CODE 128 C printing problem
I send the command ESC/POS for print CODE 128 C in SAMSUNG SRP-350 and works ok, but if i send the data 99 (0x63)the printer don´t print the barcode. You must send the data in hex from 00 to 0x63 in code 128 C to print barcode data from 00 to 99 This command work fine the printer print 1B 53 1D 68 64 1D 77 02 1D 6B 49 0F 7B 43 00 00 00 00 00 00 00 00 00 00 00 00 00 This command don´t work the printer doesn´t print 1B 53 1D 68 64 1D 77 02 1D 6B 49 0F 7B 43 63 00 00 00 00 00 00 00 00 00 00 00 00 i need a very urgent solution thanks
  • Mariano Tisera Apr 03, 2007
    i use windows driver from samsungminiprinters.com to print in wordpad using code128 commands and it doesn´t work too.
    Using wordPad Font Code128 (font installed by the driver) print characters {Caabb (read as 97979898)works fine but, {Caacc (read as 97979999) doesn´t work.
  • Mariano Tisera Apr 23, 2007
    The problem append in Firmware VER.6.30 2005.06.22, from samsung finally send me a new firmware
I have a samsung printer srp-350pg, it is printing garbiches, I download a driver does the samething, used generic driver but nothing changed
Please help
Posted on Jul 21, 2008
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
SRP-350 printing rightmost characters on the left of same line
ok..let me look at that, and then we'll find out what's up..una pregunta para tu?
es posible esta computadore no tiene los servicio packs 1.1 para Vista?
May 28, 2008 | Samsung SRP 350 Thermal Printer
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have developed an ms access POS. When i print receipt to samung thermal printer srp 350 ver 2, it prints very slow. i have tried several drivers but i end up with the same slow printing problem. I am...
itecghana, printing slow is probably an issue of the interface type (serial, parallel, usb, ethernet...) and not the printer itself. The Bixolon 350 has a self test printout capability (turn on printer while holding down the feed button) which'll demonstrate the print speed capability of the printer.
My guess is you have a serial interface (COM port), serial is notoriously slow when printing via any windows driver.
If the printer you have is a 350, one solution is to change the interface card on the printer from Serial to USB. The part number of the USB interface card is IFA-U Type, can buy one for about 35 bucks online.
Jan 10, 2011 | Samsung SRP 350 Thermal Printer
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
PROBLEMS PRINTING
Hi Anabel,
I've heard of this kinds of issue in cases where an adaptor cable (usb-serial, usb-parallel) causes this. But if this isnt you perhaps you can try reloading the printer's newest driver.
Jan 21, 2009 | Samsung SRP 350 Thermal Printer
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Thermal printer settings
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please reference the user’s manual on page 11 and 12 for dip switch settings.
Jun 03, 2008 | Samsung SRP 350 Thermal Printer
Samsung SRP 350 Thermal Printer Logo
1,192 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
