I am trying to work 2 equilizers together in my stereo set
I have 2 seperate equilizers and i will like to hook them up tomy stereo setpejohanson200
My big Q is - 'Why are you wanting to use two EQs in the first place, when one will suffice. But that is not for me to ponder over. :)
How are you trying to hookup the EQs? I have my eq connected between my preamp and amplifier. The other common method is to insert the eq in the tape loop between cassette and amplifier/preamp. Then select the tape loop to put the eq in the signal loop. You then connect your tape player through the tape monitor jacks on the back of the EQ and select this option in otder to play tapes.
If you have two tape inputs, then you can insert one eq into tape 1, and the other eq into tape 2 and choose accordingly. Bear in mind that you dont have to use the tape in order to use either EQ in your system. Just make sure you are using one EQ or the other. If you attempt to use both, then you run into potential signal 'corruption' (i.e. loss of datta or signal pumping, depending on the frequencies enhanced/attentuated).
Posted on Jan 01, 2009
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
Every time i turn my truck off the equilizer resets
If you radio doesnt save the stations either when you turn off the truck then it could be your wiring.. For example; Normally you have two power wires.. A red one(Accessory).. and a yellow one(Battery). The yellow one is like the memory.. and the red one powers the stereo when you turn the key. Try switching yours over.. See if that helps. Easily confused and you wouldnt really notice the difference.
Jan 14, 2010 | JVC KD-R200 Car CD/ MP3 Player
Need hook and eyes for my tomy train cars
Try Tomy.co.uk if you are in the UK also availabe on ebay too
Dec 17, 2009 | HIT Entertainment TOMY Thomas and Friends...
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Jun 23, 2009 | Bose 901 VI Main / Stereo Speaker
4 subs and two amps
I'm not that familiar with the insignia line but If the amps have an "input" and an "output" for the RCAs then run the RCAs in one, Then hook the output of that one to the input of the other. I did this with my 2 memphis 500Ds and it worked great. It also looks better than a couple of splitters, but yes You would just get two splitters with all female connections on them so you can plug 2 sets of RCAs into the one set. Also it doesn't really matter how you hook the RCAs up unless you are going for stereo sound then you would need to make sure the rights are hooked up together and the lefts are hooked up together. I hope I could help.
-Andrew Hawkins
Jul 22, 2008 | Car Audio & Video
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
201 people viewed this question
 Grubhead
Grubhead
