Question about Dymo LabelWriter 400 Turbo Thermal Printer
Sharing printer on a network. xp computers work vist does not.
The sole vista computer on our network will send a test page and I can see that it makes it to the printer but it will not print and goes to error_print.
  • cedricm806 Dec 18, 2008
    it is the dymo 400 turbo
    Genius:
  • 1,605 Answers
What printer is it?
if it is the dymo, then you can send a test page. you have to test the Dymo with the shipping label that is installed in the application.
P.S. I just finished installing one.
Posted on Dec 18, 2008
Printer status reads "printer offline"
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
Sep 06, 2017 | HP OfficeJet 7310 All-In-One InkJet...
Tip
Network Windows 7 with Xp and Vista
Windows 7 includes a new way to share data between all computers in the house with the Residential Group. But only when computers running Windows 7 may join the Group residential and enjoy the new features of sharing, playing multimedia files remotely, etc.. If you have computers running Windows XP or Windows Vista networking with Windows 7, you can still share your files and printers in Windows 7 "old" by following the instructions in this case practice. Below are the steps to do the same.
Check the workgroup:
To be a network, your computers with XP, Vista and Windows 7 should be part of the same workgroup.
Click the Start button. Right-click Computer (My Computer in XP) and click Properties.
In the Settings area of the computer name, verify the name of the working group. The default name is WORKGROUP but you can customize it by clicking the Change Settings button.
Make sure it is the same on other machines on the network. Under XP, the information is in the Computer Name tab.
Enable Sharing:
To enable sharing in Windows 7, you must change the settings of the Network and Sharing Center.
Click Start, then Control Panel.
Click Network and Internet and then click Network and Sharing Center.
In the left column, click Change sharing settings advanced.
Verify that the options Enable network discovery, Enable file sharing and printer sharing and Enable so that anyone with network access can read and write are checked.
Click Save Changes.
on May 19, 2010 | Computers & Internet
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
HP Office Pro K8600 not working on a network with vista
Sir,
Click this link to solve your problem
Thanks Good Luck
Aug 21, 2009 | HP OfficeJet Pro K8600 Printer
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Want to share 922all in one on xp desktop with laptop using Vista
I have a network running both an XP computer & a Vista computer. What I had to do after connecting them both to the router was make an internet connection with 1 computer, turn on the printer so everything the network was going to share was powered on; then run the network wizard on both computers. Once I did this the computer that the printer is not physically connected to installed the printer driver. Once this entire process was completed we had internet on both computers as well as both computers being able to send jobs to the same printer. Has worked great for over a year. Hope this helps you out.
Mar 16, 2009 | Dell 922 All-In-One InkJet Printer
Sharing a printer between a Vista Home Premium and XP Media Center Computer
Hi cavman6
(01) Is the Vista computer able to access ANY shared resources at all on the XP machine?
(02) Are you running any firewall software (other than the firewall built into the operating system) on either computer?
(03) If you are, please, let us know which firewall software it is and, for now, please, disable it.
(04) Do both these computers have Internet access? (I'm assuming they do but I do need to ask.)
(05) Is the printer currently ONLINE and working properly w/ the XP machine?
IF YOU HAVEN'T DONE SO ALREADY, PLEASE, DO THE FOLLOWING:
(06) Assign *both* computers to the same network WORKGROUP.
(07) Ensure that file and print sharing are enabled on the XP machine. If you'd like, do so on the Vista system, too.
(A) How to on Windows XP
(B) How to on Windows Vista
(08) "Share" the printer on the XP machine (in printer properties).
(09) Can each computer now see itself AND the other computer on the network?
(10) Have you added your user name and password that you're using on the Vista system to the users list on the XP system?
(11) If you haven't done so already, please, do this. The user name should have a password associated w/ it. So, if you aren't using a password on your Vista system profile, assign one then add that user's credentials to the users list on the XP system.
Please, post back here w/ what you've tried and the results, your observations and any other comments or questions.
Thank you
BJ @:)
Apr 15, 2008 | Extended Systems Printer Sharing...
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
Dymo LabelWriter 400 Turbo Thermal Printer Logo
91 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
