Question about LG WM-2277HW Front Load Washer
When filling up my washing machine is leaking bad.I cant tell exactly where the water is coming from.I tilted the washer up so I could look underneath and couldn't tell anything was wet,so i turned it on so i could fill it up while i looked and water started running somewhere from the underneath toward the back,behind all the pumps and things(i'm a girl so not really sure about what everything is..) If you could help that would be great...Laundry,Laundry...everywhere...lol
    Scholar:
  • 33 Answers
Dear Customer,
i'll provide you with some checks,which when performed would stop the leakage from your Washing Machine..
Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
mam i hope this would work out.i request you to please rate this solution if it meets your needs.Thank You
Posted on Dec 18, 2008
My Roper wash machine won't fill with water. You can hear it running out as it's trying to fill.
If you are right that the water is running out instead of filling then either the drain pump is bad and not forming a seal or the control panel is telling the drain pump to activate. BUT if you are not hearing the pump running then it is probably bad.
Jul 27, 2011 | Roper RAS8445KQ Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
After washing cycle starts, tub starts to leak. I tilted machine backwards and can see that water is from the drum itself but cannot tell if leak starts from top or not.
It is extremely rare for the leak to come from the drum itself. It usually comes from the fill hose at the top. The hose connecting the drum to the drain pump, or the door seal. There is access from the back of the machine, or you can take the screws off at the rear on the top of the machine, and the whole top will slide off.
Mar 10, 2011 | LG WM2301HW Front Load Washer
Washer machine is leaking water on the left corner
Hello my name is Heath it will be my pleasure to assist you. If the machine is leaking water on initial fill or when the machine is filling with water then the fill tube is the problem order a new fill tube and replace . You will have to lift the top to find exactly whaere the water is coming from.
Jun 15, 2010 | GE WBSR3140DW Top Load Washer
There is water leaking out of the bottom of the washing machine
I would check to see if the pump is leaking. Tilt the washer up and put on two peices of 2x4. Shine a trouble lite under washer and take a mirror to look under the washer. Fill 1/2 full of water and advance timer to the spin cycle. Observe to see where the water is comming from. The pump is located at the front of the washer.
If water is leaking from the pump. Replace pump.
Dec 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water leaking into washer
the seals where your water lines hook up are going bad.cant tell you which one though whether its hot or cold but its one of the seals
Jan 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
Kenmore 22422 washing machine leaking
Your going to have to take the cabinet off to get a better look at where its coming from. I can walk you thorugh it if you want. Your best to enter a live chaf for this. Thanks Dave
Dec 18, 2008 | Kenmore 22422 Top Load Washer
LG WM-2277HW Front Load Washer Logo
164 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
