Question about Jazz DV-179 Digital Camera
My camera will not turn on
It just shut off during use and will not turn back on
  • 90 Answers
Jazz cameras come with a one year warranty. If you are within your warranty period we can fix or replace your camera.
Please call 732-572-7050 and we will get you up and running again!
Thanks,
SHeryl
Jazz Products, LLC
Posted on Dec 20, 2008
Camera froze
Take out the batterys turn off goodluck
Aug 30, 2012 | Nikon Coolpix L810 16.1-Megapixel Digital...
My Canon S3IS shuts down during zooming. What's the solution ?
It could be the batteries running low. The mechanical zoom consumes battery power and at a certain point the camera will turn itself off. If you wait a minute and turn it back on it seems OK, until you try the zoom again. If you are using non-Canon batteries the camera doesn't always detect the battery level accurately and may flash "low battery" when there is still power remaining, or just turn itself off without warning. So I suggest changing the batteries and check that the battery terminals are not dirty or loose.
Mar 25, 2010 | Canon Cameras
Turns on for 2-3 seconds shuts right off battery is ok hp 707 pho
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. "Very Helpful" would be appreciated . .
Dec 06, 2009 | HP Photosmart R707 Digital Camera
My camera won't turn on.
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 21, 2009 | Samsung SL202 Digital Camera
When i turn on my camera, it shuts off right away. the battery is fully charged and it stills shuts off.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 21, 2009 | Kodak EasyShare M1033 Digital Camera
Stylus 7010 keeps shutting off battery fully charged. Turn on, access card light flashes then shuts off
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may require professional repair.
Oct 17, 2009 | Olympus Stylus 7010 Digital Camera
E217 digital camera shuts off itself during use
Had this same problem with my JP R837. This seems to have helped Try following these instructions. If the link doesn't work, go to the HP website and do a search there for FAQ's on your particular camera type.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00863607&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3319439〈=en
Jan 02, 2009 | HP Photosmart E217 Digital Camera
Camera shut off during photos and will not turn back on
camera is not not recoginising the battery may there be a battery type mismatch or battery type is not provided correctly in the software of camera
Apr 25, 2007 | Sony Mavica MVC-CD250 Digital Camera
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Jazz DV-179 Digital Camera Logo
50 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
