Question about Linksys Wireless-G WRT54G Router
Cannot Connect wireless Printer Linksys system
I can not get my wireless printer on linksys when i run lexmark peinter cd i load all the requested information and it still does not load it i have a built in wireless system in my printer. I put my ssid and password but it still does not work. Help. In Fl.
  • Anonymous Dec 29, 2008
    I have the same printer. it works when i disable the WEP. how do i get it to print with the WEP enabled? same thing for my Xbox360.
  • a-j-o Jan 03, 2009
    I have the same problem I have a Lexmark X6690 and a Wireless-G WRT54G Router I installed the software and ran the setup it asked me all the info on my WiFi network, I inputted all the info but all the printer can find is the SSID but it cannot connect to it and it said that there was no WiFi signal, that is wrong as I connect my laptop and my Xbox360 through is Router over a longer distance. Any Help :-)
  • 192 Answers
Try pluging the printer into eathernet and then try doing that.
Posted on Jan 03, 2009
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Cannot connect wireless to linksys network
Make sure your SSID and any security information matches what is on your Linksys router.
Aug 10, 2009 | Lexmark Z2420 Printer
HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Jun 01, 2009 | HP Office Equipment & Supplies
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect Lexmark X4550 to wireless laptop
I had the same problem with many phone calls to lexmark with no results.
I had a linksys router and only when I bought a netgear was I able to get them connected.
My solution was to change my router so maybe you have a similar problem with yours, definately if its a linksys as they just dont like lexmark.
Mar 09, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wireless print server
If your WEP encryption key is turned on, it will not work. To correct this, go into Internet Explorer and type in the IP address of the printer. Type in the WEP key in the correct place and save the information to the print server, then restart the search program.
There is a detailed thread I posted on this last July on Fixa. You should be able to find it by searching under the Linksys print server by the model number.
Nov 17, 2008 | Lexmark P4350 All-In-One InkJet Printer
Going wireless with Lexmark X5470
NO you cannot go wireless with the the Linksys wireless-G broadband Router WRT54GS for this printer, to check the wireless print sever you need to click on this link and then click hide/show additional results and it will cost you $149,
http://search.lexmark.com/printer/US/en/22N0000
instead you can buy a wireless printer from Lexmark X6570 which is also $149.
May 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
What are the step for setting up you computers to a network using a Linksys router. I have a 2 PC's and a laptop that I would linke to net work together. My first computer is connect to the Wireless-B...
Hi Ed, if your using windows you can open network connections & run network setup wizard. Follow the instruction for a home network for the wireless PC's & notebooks. Once the network is setup for all PC's than you can install the printer cd software in the PC's that you want to access the printer. Each PC & notebook will have access to the printer through the network.
The PC that that is connected to the printer needs to be shared.
Open printers and Faxes. Right click once on the printer & left click sharing. Agai follow the instructions.
Lastly,I strongly suggest you setup security for your wireless. If you do not anyone close can tap into your network connection. Follow linksys instruction to setup security. If you run into a problem you can call linksys for free advise from a pro. Their number is listed in the manual.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1175238819816&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1981627773H10
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Apr 04, 2008 | Computers & Internet
Lexmark 4300 series
Open control panel to activate your printer in default /check also device manager if your priter are connected w/ device.
Dec 30, 2007 | Lexmark P4350 All-In-One InkJet Printer
Linksys Wireless-G WRT54G Router Logo
120 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
