Question about Microsoft Computers & Internet
How do i get rid of a W32.SillyFDC virus
It is on all of my flash drives.Norton is picking the virus up but not AVG.
  • 20 Answers
Installing Latest Kaspersky Antivirus will surely solve your problem
Posted on Dec 19, 2008
    Scholar:
  • 93 Answers
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
  1. Disable System Restore (Windows Me/XP).
  2. Update the virus definitions.
  3. Run a full system scan.
  4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
  • Running LiveUpdate, which is the easiest way to obtain virus definitions.
    If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
    If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
  • Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
  1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
    For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
    For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
  2. Run a full system scan.
  3. If any files are detected, follow the instructions displayed by your antivirus program.
  4. Delete the autorun.inf file from writeable removable devices, if necessary.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to the following registry subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load"
  5. In the right pane, delete any values associated with the worm.
  6. Exit the Registry Editor.
Posted on Dec 18, 2008
Norton keeps blocking a system infected virus named Trojan zybot.activity15 how do I get rid of this virus
There are several programs designed to get rid of viruses. Ccleaner has a free trial program. AVG and Avast I believe also offer trial programs. I have had good success with Ccleaner and AVG. You can google to search for other cleaners as well.
Jan 17, 2015 | Dell Diamond Black 15.6" Inspiron N5110...
My computer wont load new programmes unless i disable my anti virus
I would suggest to get rid of Norton via control panel - Remove programs reboot computer and then install Free AVG. anti virus program seems more flexible with current software then the previous minimizing fire wall conflicts and issues.May get ti here or Cnet.com
http://www.avg.com/us-en/trustav_bt_ppc?ctype=ppc&utm_source=google&utm_medium=cpc&utm_term=free%20avg&utm_campaign=US%20AVG%20Free&gclid=CPO635vKxLICFQQ3nAodA1sACw
Sep 20, 2012 | Acer Aspire One A150-1006 Notebook
I just received an email from a contact I deleted, because he told me not to open any from his because he has a virus. Now why doesn't my protection company pick that up, Norton, or AVG, I have both...
First of all, having two Security Program in your laptop is not a good idea. Most of the time it creates conflict and would result into some sort of confusing each other whom would detect that virus. Other than that, having two security software would slow down the computer performance as both programs would eat large amount of your RAM. Best thing to go here is to uninstall either AVG or Norton. I recommend AVG as it has this feature called Email Scanner which would help detecting such virus that goes through emails. For more AVG FAQ you may check. www.avg.com/faq
Oct 30, 2011 | Microsoft Windows Vista Home Premium...
Apparantley i have a trojan worm in my lap top, i have norton and caled them they say i have a problem and my laptop is out of warranty and i have to purchase another one is this true
NO, you do NOT have to purchase a new laptop.
What the people at Norton probably meant was that your Norton anti virus software has expired and you need to purchase a new anti virus subscription from Norton if you want them to help you.
There are however other anti virus software manufacturers out there that are free and/or will allow you a 30 day trial period.
To help you clean out the worm in your system:
  • Find out the name of the worm you have on your system (your norton program will tell you this).
  • Go to this page: http://free.avg.com/us-en/virus-removal
  • Click on the link that has the same name as the worm on your system (don't worry about the I-worm or W32 part of the name, e.g. if your worm name contains navidad you want to click the I-worm/navidad link or if your worm name contains bugbear you want to click the I-worm/Bugbear.C link etc.)
  • Follow the instructions on the page you get to in order to get rid of your problem.
Hope this helps ;)
Jan 28, 2011 | Acer Aspire 3680 Laptop
I believe my registry (winxp) is infected with w32.ahmanahe.b!inf After installing Nortonanti virus 2009 and scanning and cleaning the system it keeps coming back. Norton blocks it but their teh support...
If Norton scans it and tells you it's there, it should remove it.
Here's what I would do:
Go to this site:
support.f-secure.com/enu/home/ols.shtml
and scan from there.
Also a really good resource is www.bleepingcomputer.com. They have a usegroup devoted to malware and usually can com up with a solution faster than any other place I've visited.
Oct 04, 2009 | Microsoft Computers & Internet
Norton Internet Security 2009 Causes Blue Screen of Death.
Hi there
Thats Norton for you! this is a very heavy and memory hungry program, it takes control of your computer and if you have not got enough system or virtual memory it will cause the pc all kinds of problems. To fix this either upgrade the system memory or don't use Norton, use AVG free instead, its a lighter program and lets you have some speed back over the internet.
good luck and thanks for using Fixya!!
Feb 11, 2009 | Symantec Norton Internet Security 2009
I need help.my computer is aving trojan virus.which antivirus software remove virus?
AVG free edition should do the trick, but the safest way to get rid of a virus is reformatting your hard drive.
free.avg.com
Dec 29, 2008 | Computers & Internet
W32 Virus
Kaspersky AntiVirus is Best ....
Download Kaspersky Antivirus and your problem will be solved...
Dec 20, 2008 | Microsoft Windows XP Professional
Can't get to Norton to turn it off.
you can..and go to pack.google.com to get a free version of Norton Net Security
Apr 21, 2008 | Sony VAIO K45 Notebook
Computers & Internet Logo
663 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
