Question about Audiovox DC400 Camcorder
Little LCD view screen only shows slanted blocks of multicolors after power on ??? :(
I really loved this little camera/camcorder and used it a lot. Daily in fact, packed it around with me everywhere. (Camera is worthless if not with you!). The view screen just will not go into normal mode after powering on and has only just about came back to normal only once but was slanted like the multicolor blocks and didn't zoom or take pictures or have menu working or anything and when re-powered up was back to the blocks. These blocks do have zoom, (seeing little bar move up and down not the blocks getting changed around), and no pictures with menu working but also seams to be stuck in camera mode only and not switching to other things like normal. Did just once also yesterday after not touched for a few months power up to a half white and half black screen with white on right side and black on left side this also will not zoom or take pictures or have menu working. This only lasted about a few minutes and back to multi-blocks. Today I've opened it up and pushed on all the connections to make sure they are fully seated and not knowing about screws under bottom model number sticker I've busted a few more plastic clips inside, a bit like the busted ones that used to hold battery/card door closed long ago. Thats when this all started, when I super glued, (glue job was done very well with out any extra getting anyplace else!), a tiny plastic clip chunk back into place trying to not have to have the camera held together with rubber bands anymore. I'd been holding the door closed with rubber bands for a year or so. Afet the neck strap broke and camera started to get dropped a lot the little locking closed clips started to bust and only way to keep the door closed was rubber bands luck. I really miss this and wanted to figure out a fix. Would an old battery with fewer AmpHr's or maybe a bit lower voltage do something like this ????????? I thought the battery was acting up a bit before this started. THANKS
2 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
poolseman
  • 206 Answers
SOURCE: DC400 Screen only showing slanted multicolorlines
No this is clearly a CCD sensor problem ( CCD generates image in v-cams and still digital cameras ) if the sensor is outputting too much noise then your image will be distorted just like yours is. If the sensor is outputting nothing then camera shows blank screen ( also notice that with this problem you can playback OK ). Replace CCD block.
Posted on Sep 06, 2007
Lcd screen view is reversed. In other words everything you view on the screen is reveresed, like looking in a mirror.
It's a loose cable connection in the LCD. Mine started to do that and if I push the open LCD panel toward the lens slightly it corrects. I have a little tutorial I made on how to take it apart here: http://www.tomorrowsgarden.net/content/how-repair-canon-vixia-camera-black-screen-issue
Jan 16, 2011 | Canon VIXIA HF20 High Definition Camcorder
I have a blank screen
You must say a little more when you post for help, blank screen where? The TV, The mobile Phone, The Camera LCD screen? the view finder of the camera?
May 21, 2010 | Sony Handycam CCD-TRV98 Camcorder
I have a JVC video camera modelGR-D290U. I can play and view tapes previously recorded.But when loading a new blank tape the screen does not show what is being recorded and remains blank when rewinding and...
Sounds as though the imager may have failed but make sure you are in video postion instead of memory mode. Little switch behind the lcd screen. Larry's Electronics
Apr 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
I cracked the viewing lcd dusplay on my sony handycam dcr-dvd 308. Can I get a new one to replace myself or should I just throw the camera away? Sony price for repair is way more than the camera is worth
You can replace LCD in this camera by yourself with little expertise, open LCD section cabinet as it has few screws around. Required LCD part number for DCR-DVD308 camcorder is...
A1202057A TP Block Assy
Available in Next Tronics for $175
Oct 20, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
LCD View screen problem Sony DCR-HC42
well if i'm not mistaking it could be the LCD board connection at the screen . but the replacement + labor will go from 120 to 170,
have you tried to open the screen, really slowly and see if it shows any life !.
you can try to get an stimate at sony, and see how mush it will cost you repair the machine.
there is not easy way to fix it, the screws are small and they can be lost really easy.sorry
Oct 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Do we have option to take pics through LCD in Nikon D40X?
Hi. No you can't shoot by viewing the LCD, only by using the eye-level viewfinder. Some SLR cameras have "live-view", which lets you use either the eye-level finder or the LCD. It really isn't a very good method of shooting with an SLR, as you first have to lock the mirror up, compose your shot, then drop the mirror back down. Using the eye-level finder also blocks out the bright light that makes the LCD difficult to use in sunlight. Hope this helps answer your question.
Apr 13, 2009 | Nikon D40X Digital SLR Camera Digital...
Black screen on camcorder
I think you have two different issues here. The black screen may be due to a CCD failure. Canon has a worldwide service notice regarding this issue, and will repair your unit at no cost if they determine this is the problem (it sounds like it is).
The little red symbol indicates your backup battery (or date/time battery) CR1616 needs to be replaced. It is located behind a small square panel which you can see to the left of the menu buttons when you open the LCD panel.
Dec 08, 2008 | Canon ZR70MC Mini DV Digital Camcorder
LCD NOT WORKING
Your batteries need to be replaced. Need new batteries.
Oct 24, 2008 | Canon PowerShot A85 Digital Camera
Sep 06, 2007 | Audiovox DC400 Camcorder
Video Cameras Logo
52 people viewed this question
Top Audiovox Video Cameras Experts
NOEL
NOEL
Tony Parsons
Tony Parsons
Are you an Audiovox Video Camera Expert? Answer questions, earn points and help others
