Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
QUIT COOLING AND FREEZING
  • Whirlpool Master
  • 8,220 Answers
One thing you can do is make sure the coils underneith the machine are clean and the fan motor is turning. The kickplate is clean. Next you can grab the compressor relay off of the compressor and examine it.It has a floating start relay within it and should make a thunka thunka noise when shaken. If it makes no noise it is bad. If it sounds like a salt shaker or smells burned it is bad. If that is ok then find the defrost timer and see if it got hung up in the defrost mode. If that is ok check the temperature control for continuity. If that is ok then I would say maybe I would but an A-1 line tap on the suction side of the compressor and check the pressure on the low side. It should be no less than 5 PSI and no more than 8 PSI. Anyone can get R134a at automotive stores. If you have no guages then add no more than 3 ounces. If the low side begins to frost over badly then you have too much in there.
Posted on Dec 18, 2008
I would like to no what way the switches go on my freezer
take a picture of the switches and the model and serial number tag and post here... what part of the freezer freezes up? does it quit cooling?......... ken
Sep 29, 2014 | Refrigerators
Westinghouse problems
From your description you have a defrost issue. I would look into why this is not defrosting in a timely manner as it is designed to. I need a model number to asset you further. Good Luck
Aug 29, 2014 | Refrigerators
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My kenmore sidexside quit cooling and freezing. Repairman said it was the relay and compressor without using any tools. Relay was burnt. How can he know the compressor is out too? model 106-54502300
Good day,
He can't, although it's a good guess. However, The compressor can be tested and run with a special test cord most all techs have.
It allows the compressor to be run independent of the rest of the machine and is the definitive test. I would not go forward unless that test is performed. Compressors are too expensive.
May 10, 2010 | Refrigerators
Not cooling or freezing quit all at once fan still works in freezer
Might have a bad start relay, compressor failure, or a sealed system leak.
If you hear a slight hum, then a click- it's either a start relay issue -or a bad compressor
Affordale Appliance Repair
Lake Forest, CA 92630
Aug 21, 2009 | Refrigerators
Amana refridgirator not cooling
check thermo stat or defrost timer and all elec. connections
Aug 12, 2009 | Refrigerators
For the second time this year my fridg is quit working. I is only about 7 years old. It is not cooling on either side. The ice maker is not freezing the ice very well it ends up freezing in lumps that we...
Check behind the fridge where the compressor is and see if the condensor fan is working,also clean all the dust out of the fan area eg condensor. Hope this helps Kind Regards.
Jul 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
166 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
