Question about Memorex Audio Players & Recorders
CD Alarm Clock displays NO DISC when attempting to play a CD.
I have done all the troubleshooting suggested in the manual and it still displays NO DISC. I was playing a book on tape, all was fine, the alarm was accidently set, it went off during CD play, and it has not worked since. I've tried different discs, double checked to make sure the door is closed tightly, and I see no dirt or smudges. This player gets used everyday, I've had it about 6 months. (That's just FYI) Could the alarm be the culprit? Model # MC7100 Suffix A
Thank you, Marsha Goetz
  • mgoetz1015 Dec 22, 2008
    Wow, am I glad I discovered this website. Extremely helpful and very prompt with solutions. Koodos!
    MMG
    Problem Solver:
  • 7 Answers
Try cleaning the lense using a cd lense cleaning kit/cd. this usualy helps. if it doesnt work, repost
Posted on Dec 19, 2008
My Philips under cabinet radio / CD Player - 3-4 years old is showing two problems: 1) The light behind the LCD display if often off - but not always! 2) The CD Player plays the disc in it, but does not...
Seems a lot of reports like this have been noted and unfortunately the FIX cost more than replacing the electronics. My suggestion...make your move to a new unit.
Jan 31, 2018 | Philips Under-Cabinet Alarm Clock Radio...
For the Trutech cd clock radio (cd1189) I am attempting to get it to play a particular cd track as an alarm. Is this possible, or can I only play the first track?
I think it will only play the first track.
You can "rip" the original CD and then "burn" the track you want to a blank CD as track 1. I believe this is the only way possible.
Apr 13, 2011 | TruTech Clock Radio
I Have a Philips CDR820. The problem I have is that the system is "freezing up" and wont play. The troubleshooting manual says to unlug the player for a short time and plug back in. I do this...
What does the display read when this happens, I have experience with these, does it say disc recover? also when the laser reader gets old, it may be done, unless you can maybe find someone with replacement. Old or scratched cds won't read well, or skip also.
Jan 01, 2011 | Philips CDR820 4-Disc CD Recorder
It is not playing any dvd's. It says invalid or
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
1. Ensure the Easy Setup procedure has been completed on the BD player.
NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
2. Ensure the inserted disc is compatible with the BD player.
NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step.
NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
4. Use a soft cloth to clean the disc.
5. Examine the disc for any cracks or scratches that might be interfering with playback.
6. Attempt to play another disc.
NOTE: If another disc plays in the player, then the previous disc may be faulty. In this case, contact the Customer Information Service Center at 800-222-7669 to speak with a customer service representative for further troubleshooting.
7. Remove the disc from the BD player.
8. Turn off the BD player.
9. Unplug the power cord of the BD player from the electrical outlet.
10. Let the player remain without power for 1 minute.
11. Plug the power cord back into the electrical outlet.
12. Turn on the BD player.
13. Insert the disc into the BD player.
14. Attempt to play the disc.
If the issue is not resolved even after performing these steps, then try installing the latest Firmware update if you have not done yet.
Here is the link to download and install the Firmware update.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS360
Select the correct Operating System and download the Firmware update.
Then follow the instruction on the same to install the update in the Player.
If the issue is not resolved even after installing the update, then Playe may require service.
Jul 21, 2010 | Sony BDP-S360 DVD Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
The CD player on my Sony Dream Machine FM/AM CD clock radio will not play. I have left the CD compartment open per the troubleshooting instructions in the manual, to remove moisture but to no avail. When I...
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Jun 26, 2009 | Sony Dual-Alarm AM/FM Clock Radio with...
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Feb 04, 2008 | Bose Wave Radio
CD player stopped readiing disc.
Same here. The open/close CD door button doesn't work either. Did you ever get this resolved? -pokie
Oct 28, 2007 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
165 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
