Question about Brother MFC-9420CN All-In-One Laser Printer
Blank lines on right side of paper on brother 9420 mfc
I have just replaced the fuser unit that was pitted and still have a line of white lines running down the right margin of the paper, any suggestions. The OPC belt still has 94% life on it according to the menu readout.
  • ckmayeaux Jan 12, 2009
    I did lift the cover on the glass laser and cleaned it and checked cartridges, still have a line on the left side of the page running the full length of the text, not sure what to do next
    I took out the cartridges and openned that small black door on the bottom of the unit, but I really did not see a glass, it only looks like a small track to me. Which I tried to clean with a soft cloth.
    Funny, the instruction sticker down there says to not swing the door back to open but that it would open from the back moving forward, mine is just the opposite, it only open to the back (center) of the unit.
    Am Iooking in the right place for the laser glass, do I need to open something else to actually find the glass. Also, how do I run a test page to see if it is resolved?
    I really appreciate your willingness to help.
  • 215 Answers
If it does this on all colors, try cleaning the laser **** glass located below toner cartridges. you could have drops of toner on it. if only certain colors, visually check your toner cartridge rollers.
Posted on Jan 09, 2009
  • Ray M. Jan 12, 2009
    you cleaned laser glass and NOT scanner glass, right? i didn't mean glass on top of machine. do an internal test print, not a copy or fax. is it on the internal prints? if so, and you think you might not have cleaned the laser glass, try that. otherwise, i'm not sure.
My printer is suddenly printing faint, mostly on the right side of the paper.
The high voltage supply is not working right. That is what forms the toner on the paper. The fuser wire gets hot and melts the toner to the paper. You need to have the power supply looked at.
Feb 17, 2016 | Brother MFC-7460DN
When i print, theses black lines appear on the side of the paper
Hi Good day!! Try to replace the toner of your unit and try to print some test page. if the problem is still there check the fuser film. check if there is damage in the film..
feel free to ask me if you have any question..
Aug 30, 2012 | Brother MFC 7840W Printer
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
How to remove fuser from a brothers MFC 8860DN and reset the counter
WRONG! Press 2 and 8 at the same time to reset the counter.
Apr 20, 2010 | Brother MFC-8860DN Printer
How do i reset the life of the fuser on the mfc 9420
Actually the Replace Fuser message on these specific models sometime fail to reset after you replace the part.
If this happens:
Press Menu 6,3 and then select option 4 (Fuser)
Press okay
Press Stop/Exit
If you haven't replaced the unit then you should try that first.
Additionally If you are an unhelpful troll, don't post your ad-homonym attack as a solution.
Feb 18, 2010 | Brother MFC-9420CN All-In-One Laser...
Black and white brother printer it lighting drum error
If your drum has a line, then you have to replace another drum unit.
Jul 08, 2009 | Brother MFC-7820N Printer
Why does my MFC 9420 keep getting a paper jam in the back (at the fusing roller)?
Perhaps the fuser drive gear is broken or there is some object stuck in there. When it's printing, check to see if the fuser rollers are turning. Drive gears do occasionally break.
Apr 22, 2009 | Brother MFC-8440 All-In-One Laser Printer
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Aug 25, 2008 | Brother MFC-8440 All-In-One Laser Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
340 people viewed this question
James Cagle
James Cagle
Jim Keysor
