Question about RCA D52W19 52" Rear Projection Television
Rca 52w59xy23 BECAUSE MY FLYBACK DIDN'T COME WITH ANY HV CABLE. HOW CAN I USE THE OLD ONE OR HOW DO I GET REPLACEMENTS?
  • REEOS Dec 18, 2008
    my fly-back is the original so the hv cables don't come out.
  • 585 Answers
It's not just any old piece of wire. It must be insulated to withstand the 30,000 volts the wire inside the insulation must carry. Look carefully at the old flyback, there may be a gray cap around the old lead. The cap has a "push and twist" to release it, thereby allowing removal of the lead. Removes much like the old style panel mount fuse caps used in older equipment.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 19, 2008
  • RCA Master
  • 5,138 Answers
Some companys send extra wire lead but most of the time you remove your old wire and use it .
Posted on Dec 18, 2008
  • ladywinn
    ladywinn Dec 18, 2008
    High voltage wire is just a wire!
Where is the verticle output IC on my 52 inch rca projection tv
if you remove the rear panel you will see the board on the far left has a large transformer with a large red HV cable coming out of it. Thats the flyback. Now look to the right side of that board in line with the flyback. The aluminum heat sink with the fins has the verticle IC. Its the first heatsink closest to where youre looking on the right side of the board with the flyback.
Dec 06, 2009 | RCA R52WM24 52" HDTV Projection Television
Short circuit in my rca tv projection
most likely the flyback as the RCA is famous for defective HV Distibutors and the Flyback.
May 23, 2009 | Televison & Video
Power supply sparks when tv is turned on
That can either be the Flyback or the HV splitter. The flyback is located on the lower left hand side when looking in the rear and has a large red cable coming out of its top. The HV splitter is located in the front in the center of the set. These are both very easy and inexspensive to replace. I can post a link where you can get replacements with instructions.If you would like.
May 08, 2009 | RCA D61W20 61" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
New Flyback old one wont come out
if you dont know what the second anode is you should not be working on this set. on some the lead comes out of the flyback some it has to be removed from the hv distributer block. output transistor probably bad also......
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
Rca hd52w59 power button lights up for 10 sec than shuts off
the flyback is 259296 you will also most likely need cP150 you can get replacements with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
POPPING NOISE
mine did the same thing on a cable line and then i put rca cable on it and it never did it again
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Flyback and hv splitter
7 months old should still be under parts warranty from RCA.
Apr 09, 2007 | RCA HD52W58 52" TV
RCA D52W19 52" Rear Projection Television Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
