Question about Iomega Jaz 2GB External JAZ Drive
Not able to access the Jaz Disk
I recently want to back up the only info on Jaz disk 2 GB. It came with a sci cable with two adpters one to the Jaz drive and the other to the printer port. I downloaded the installtion software and installed. I see a disk IMG VPO in the hard disk but when I double click to see the contents it says please insert a disk. I am using a dell pentium 4 running on Win Xp. Please help me.
    Problem Solver:
  • 22 Answers
Iomega has quite a bit of customer help info: https://iomega-na-en.custhelp.com Click: Other Products Then Click: JAZ 2GB Then Click: Windows XP Then Click: More Answers... Then type in "search text" area: "insert a disk" Then Click: Search Then Click: "Please insert a disk into drive X" error message when inserting or trying to read an Iomega disk If that website's search engine doesn't help, you can also log into: http://www.iomegasupportforums.com and ask the tech support people there.
Posted on May 30, 2007
Hai sir whenever i insert any kind of pandrive,it shows its all data but i can't copy or cut it to any of my pc,shows access denied????????? what can i do now?
For tweaking the USB access you can find the info and the working settings over here: http://www.mydigitallife.info/how-to-disable-write-access-to-usb-hard-disk-and-flash-key-drives/
NOTE: these settings work only for Windows.
Apr 26, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can't get the drive to tell me what is on it. Should have about 2 gig of info. I have no instructions on how to actually back up the drive. I can't reach WD for assistance. Thank you. A Frank
An external file-storage device has 4 major components:
* a USB cable,
* an "internal" disk-drive, inside the enclosure,
* a USB-to-disk-drive adapter, inside the enclosure,
* an external power-supply.
Try a different USB cable.
Try connecting the device to a different USB port on your computer.
Try connecting the device to a different computer.
Take a multi-meter, and measure the actual voltage & amperage outputs from the power-supply, and compare to the specifications on the label on the power-supply.
Open the enclosure. Remove the disk-drive. Connect the disk-drive as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
Search online for a professional "data recovery service". For a significant fee, they can repair the disk-drive just long-enough to read your 2GB of data, and copy the files either to a new disk-drive, or to burn the files to a few CD-R disks or to one DVD-writable disk.
Nov 03, 2010 | Western Digital My Book Essential Edition...
The usb port is broken? how can i get to my info on the drive?
Open the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' disk-drive in some computer,
to access the files.
Or, for about $30, buy a new 'empty' enclosure, and transplant your disk-drie into that enclosure.
Oct 26, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Samsung 250 GB portable HDD is not recognised now. It was working for last 2 years without any problem. Recently I found my PC infected by "WIN32" & Torjan viruses. It may be the reason. But I tried...
Try connecting it to another computer.
If it does not work, then either the disk-drive has failed,
or the USB-cable is damaged,
or the USB-to-disk-drive interface inside the case has failed.
Is the SAMSUNG still under warranty? (1 year? 2 years? 3 years?)
If so, SAMSUNG will replace it, at minimal cost to you.
Sep 25, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My 3100 worked for about 2 years and the other day
If the fan does not come on at start up try this replace all electrical leads that attach to your hard drive including IDE,SATA leads if still no work replace PSU
Jul 30, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hitachi 80 GB. USB HDD problam.
If you plug it in and it does not appear, it may be choosing the wrong drive letter.
If that drive letter is already in use it will not appear.
Open the start menu, right click on my computer, then choose manage.
Select (on the left) Disk Management.
If it appears in there.
Find the thumbdrive in the list and right-click and choose 'Assign a new drive letter' . Make it like M or somthing far down in the alphabet.
If that does not appear under the disk management then the disk might be physically damaged.
An urban myth (which does sometimes work) includes putting the drive in the freezer for a day or so.
Also remember it might be somthing as simple as a bad cable or port on the computer. Try to access it with a new cable from a diffrent computer.
Apr 23, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Formatting a disk
Iomega drives had a short life and then were overtaken by other technology. They were/are very fragile and had a high fail rate. Time to move on I guess - burn a disk or two.
May 16, 2007 | Iomega Jaz 1GB (10771) Internal JAZ Drive
Help with big extreme disk partition access.
Don't know what operating system your using but in Windows 7 and up it's easy to partition any drive even while windows is running.
Go to --> Control Panel\Administrative Tools\Computer Management\Disk Management and right click - set the size.
You can change it any time as long as whats in it isn't bigger than the size you want to make it. I have a 1 TB in this computer and that's how I did it after discovering that my old drive tools didn't work on this.
For any info on this procedure (or darn near anything you can think off) you can always go to youtube for step by step instructions.
Just watch a few first because some people are better teachers than others.
Mar 13, 2017 | LaCie Bigger Disk Extreme 2000 GB Hard...
Iomega Jaz 2GB External JAZ Drive Logo
332 people viewed this question
Top Iomega Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Alun Cox
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
