Question about Canon PowerShot A410 Digital Camera
Camera wont turn on
My canon powershot A410 digital camera wont tun on i put new batteries 3 times but it just wont turn on
  • 2 more comments
  • alanpayless Dec 31, 2008
    I have same problem i cannot turn on my camera.
    Any bady can help me send e.mail to
    alanpayless@gmail.com.
    Best regards
    Alan
  • cmburns708 Jan 04, 2009
    I have the same problem. It started powering on intermittently several months back and then stopped altogether a month ago. Several brand new batteries have been tried. . .to no avail.
  • delila1 Jan 05, 2009
    I have the same problem , please help ??????
  • Anonymous Feb 15, 2009
    I have had the same problem with mine.
I just posted that I have this problem as well. Then, after browsing further at Canon's site, I found a possible link between the memory card and the power problem. Sure enough, I popped the memory card out and reinserted it and the camera powered right up. I hope this helps others. . . .
Posted on Jan 05, 2009
I am getting memory card error with canon powershot a410
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
Sep 23, 2012 | Canon PowerShot A410 Digital Camera
Digital Camera CANON PowerShot A410-No VOICE Record
I'm sorry to tell you, but the PowerShot A410 model does not have a microphone to record voice. Of all the A400 models, only the A410 and A420 were made this way. For some unknown reason, Canon decided to not include micorphones wiith these two cameras, thus they can only record video, but no voice.
Dec 25, 2009 | Canon Cameras
Camera gives E18 error!!!
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Oct 03, 2009 | Canon PowerShot A410 Digital Camera
I left AA batteries in my Canon powershot A410 too long and now there's battery acid on the battery board. I replaced them with new batteries but the camara is still dead. Did I destroy the camara ?
You may be able to salvage the camera if the only thing the acid did was corrode the battery contacts. Use some light sand paper to clean the battery contacts down to bare metal. The contacts on the battery door should be easy to clean. However, the spring loaded contacts down inside the battery holder may be hard to reach. You can try using an eraser on the end of a pen or pencil to reach down in and buff the tops of the springs. I recommend using a pen eraser because they tend to be more abrasive. After you've cleaned teh contacts the best you can try putting in new batteries and hope for the best.
Jun 08, 2009 | Canon PowerShot A410 Digital Camera
Canon PowerShot A410 Flash Question
hi there
when in camera mode do the following
look at the multi function dial
at the 3 o'clock position you will see a lightning bolt
press it and select the bolt with a line through it
press the func set button and its off.
do the reverse to turn it on.
hope this helps
beergut707
Oct 25, 2008 | Canon PowerShot A410 Digital Camera
Canon A410
may be a IC inside have been broken. there is very little chance of camera surviving
Oct 03, 2008 | Canon PowerShot A410 Digital Camera
Date and time settings
The date battery needs to be replaced. It is a coin-type battery, CR1220. It fits in a holder that slides out from the bottom of the camera, opposite the side from the battery cover for the regular batteries. When putting the new battery in the holder, the negative side of the battery should be visible. Illustrated instructions are on page 87 of the Advanced User Guide.
Jul 26, 2008 | Canon PowerShot A410 Digital Camera
Faulty Canon Powershot A410 Digital Camera
I have answered this in another post. Here is the link.
If this helps you, please return and choose FixYa! ThankYa!
Dec 04, 2007 | Canon PowerShot A410 Digital Camera
Continuous video capture
Hi, The A410 can only record a maximum of 3 minutes. That sucks becasue it doesn't matter what resolution you use, it will max out at 3 minutes. NewMediaMan
Apr 24, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot A410 Digital Camera Logo
243 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
