Question about EverFocus EDSR1600/500
Key to remove hard drives
The hard drive has failed (I think), and I can not find the key needed to remove it from the machine.
  • 4 Answers
You can either pick or drill out the lock. I would recommend trying your lock picking skills first- there's nothing to lose! I use a small flat blade screw driver and a straightened out paper clip. (you can google how to pick a lock. The locks that use the round key can be picked easily too.)
Make sure the power is unplugged from the PC. If it is a slot keyhole you should be able to drill out the center usind a 1/4" drill bit. You can do something similar to the round keyhole locks also.
Good Luck!!
Posted on Dec 19, 2008
No connection between my internal hard disk and my laptop
Hi
The ref number you give is for the hard drive only and not related to the laptop, so I can only be fairly general. Often on laptops the hard drive is fairly easy to get at and I would first check that the drive is securely seated and firmly connected to the SATA connection inside the computer. Remove the battery before removing the drive cover.
If it is securely connected, try powering up again. If this doesn't work, power the machine off completely by holding the power button down for about 10 secs. Press the button again and during the early part of the boot up sequence press the relevant button to enter the BIOS programme. I can't be sure which particular key starts IOS setup for your computer as they vary quite a lot. Your manual will tell you however. On my Toshiba for example its the Esc key, on others its the F2 key, and others the Del key.
Once in the BIOS you should be able to navigate through the settings and find out if your drive is being recognised at this level. If it is then try to boot into "Safe Mode" to repair the installation, otherwise it probably needs to be reformatted and the recovery disks used to revert to factory settings. If you do this you will lose all your data and non Toshiba programmes that you have installed.
If your drive is not recognised in the BIOS, it is highly probable that the drive has become faulty and needs replacing.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
How can I start when Default boot device missing
Good day Ken Markham
If your "Default Boot Device" is your hard drive and it is missing, then your machine will not start, you may need to have a technical person look on your machine for you.
Nov 20, 2014 | Computers & Internet
Boot failed
Is the optical drive a DVD drive?
Have you set the machine to boot from the optical drive?
Frequently the HP boot sequence is accessed by touching the Escape key on boot.
Dec 12, 2013 | HP ProLiant DL120 G6 Rack Server System...
How to instal new hd advent 7070
You should be able to get into the BIOS or Setup without a hard drive. Power on the machine and notice what function key it tells you to hit to get into the bios or setup.
Most laptops have a cover on the bottom that once removed, the hard drive goes there. Normally you will see 3 circular discs that represent the hard drive. You'll need to know whether your drive needs an IDE or SATA hard drive. Laptop hard drives are 2.5 inches or just ask for a laptop hard drive. Since the drive is missing the caddy that holds the drive in place might be missing too. And some laptops be it IDE or SATA uses an interface that sticks on the drive too. I think you need the help of a professional. I'd say you're looking to spend $80 - $125 just on parts depending on what is missing and needed.
Mar 19, 2012 | Computers & Internet
My XP machine does not show the Western Digital 80GB hard drive that I have connected to it. In fact it does not show ANY external drive. The WD800U017 is perfectly fine. The machine reports that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Let me know if you need further assistance. Thanks for using FixYa
Nov 21, 2010 | Western Digital Passport WDXML800UE...
Disk boost failure
WEll not good. I suggest being VERY careful at this step. First thing to try is to look at the bios settings to be sure that your hard drive is listed.
BUT
I think data loss is very close. My preference is to pull the hard drive and connect it to a working system, and extract all user files.
After that, have the good system do a disk check on the drive in question, while hooked up. Have your antivirus check it, too...
So, the next steps vary based on the results of these first steps.
Hard drives do fail, and we actually proactively replace drives on key machines.... Waaaay easy to migrate files from a working drive..
Sep 20, 2010 | HP Compaq Presario SR1330NX (PP161AA) PC...
Dell inspiron 1525 cannot find hard disk
hi there !
-remove the hard drive of the computer and remove the cdrom drive
-after removing the hard drive and cdrom drive; return them again
-turn the computer on then press F2 and look at the device info
take note of the information
Hard drive =
Fixed Bay Device =
-run diagnostics on the computer
-turn off the computer; while the computer is off, press and hold the Fn key then press the power button at the same time, once the computer is on, let go of the keys
*if you get an error 0141; and the status on BIOS is Hard drive = none then it is a faulty hard drive
cheers !
Oct 28, 2009 | Dell Inspiron 1525 Notebook
Mi laptop write the following information when i try to start up- 1720-SMART hard drive detects imminent failure (failing Attr please back up the contents of the hard drive and run HDD self testin F10...
Smart thinks that the hard drive is in fact failing, so you need to copy all your files to CD/DVD/USB key/External Hard drive, and then replace the internal hard drive and reinstall the system.
Having said that smart has been known to continue putting up this warning for lengthy periods, so it is possible that the drive will continue for some time. If you want to risk it, just continue to use the existing drive until it fails and back up all important files as they are created.
Aug 01, 2009 | Computers & Internet
No internal hard disk found after laptop is closed?
To fix this problem you would need to try this.
*Run the psa test
1. press the 'fn' key and power key together, it will automatically launch a diagnostic test, follow the onscreen instructions confirm if it comes with any error code (it should come up with 0141 error code if it is a hard drive problem).
2. check the hard drive status in bios (check if it is being detected).To do this you would need to switch on the laptop and start tapping F2 key (multiple times, especially at dell logo). this will lead you to bios. using the down errow key on the keyboard, go to device info and check the first option on the right hand side (primary hard drive). confirm if it is detecting the hard drive or it says none or unknown.
3. Remove the optical drive by following the link (support.euro.dell.com) and check if it works after removing the optical drive. This is because optical drive can cause the hard drive not to work properly as they are interconnected with each other.
Once you have performed the above steps, confirm so that I can suggest you the rest of the steps accordingly.
Regards,
Musheer.
Jan 06, 2009 | Dell Inspiron 1525 Notebook
SMART error
i think u have to try to RE-install OS
Nov 03, 2007 | HP Compaq Presario v3000z Notebook
Televison & Video Logo
364 people viewed this question
Top EverFocus Televison & Video Experts
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
