Optoma EP745 Will not turn on
We replaced the lamp, and when we went to switch it back on the projector did not respond.  The manuals simply tells us to call support, who cannot help us.Have an Optoma EP 745. The color wheel shattered. Am looking for a replacement color wheel, but when I first checked my lamp and placed it back in (it was OK) I had the same power off problem. Will not turn on. Am guessing that if I get the color wheel repaired, I will have the same problem. Don't want to chase goo money after a bad projector.
  • 2,336 Answers
If one the main parts like the color wheel or the lamp are not in working order the projector will not power up.
Click here and try the phone number from the last post and see if you can buy the color wheel.
At this point is up to you if you want to spend more money to fix the projector.
Posted on Dec 18, 2008
  • 679 Answers
You are correct, there gets to be the point of no return with this kind of problem, even if you get it working, something else will blow, and now you find that you spent all this money and it went to waste. It sounds like this is the situation with this problem, so instead of sending you to all of the websites to fix the problem, "maybe", I agree with what you said perhaps a new one is the way to go. I just hd the Tv in my bedroom go, and will not even bother with fixing a ten yr old tv, Something else will go next month, treat yourself to an early Christmas present. Peace, to you and yours, Gym
I went to replace the bulb and when I plug it back in there is no power, no power light or anything. DS303
this is a common problem with optoma projector, if you replace the lamp yourself, it won't start!! let's sue them
Jul 16, 2011 | Optoma DS303 DLP Projector
Turns on and calls for replace lamp, I already did it and still calling for replace lamp. Fan turns on and that's it power and lamp lights are on thanks
Projectors keep a lamp life clock to track the age of a bulb. The clock needs to be reset with each bulb that is inserted. Here are the steps with your particular projector:
1)Power on projector
2) Go to "menu"
3) Choose "Options"
4) Choose "Lamp Settings"
5) Choose "Lamp Reset"
6) Select Yes
Certain models require you to hold "Lamp Reset" for a particular amount of time. It could be instantly, 3 seconds, 5 seconds, 10 seconds... Just have to play until it responds.
Once that is reset you should be good.
Mar 08, 2011 | Optoma PRO250X Projector
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Used my OPTOMA HD70 ABOUT 2years now -and had to replace the lamp i unplugged it and when turning it back on to work - it does not start , it`s dead the green led lamp does not flicker , does not work...
There is a switch on the side where you insert the lamp, it's black with a metal contact. If, when the lamp cover is replaced, it does not "activate" this switch for some reason (i.e. it is loose or perhaps bent) then the projector will not power at all.
Just remove the lamp and take a look at the switch for possible damage incurred from when you replaced the lamp.
Sep 29, 2010 | Optoma HD70 DLP Projector
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
I have an Optoma EP745 projector. I heard a 'pop'
check all the fans, if still working. if the problem occur get assist to the nearest technician im sure your lamp balasst was deffective.
Oct 22, 2009 | Optoma EP738 Multimedia Projector
Optoma HD65: no power after replacing lamp
i was blowin air in the back vent and i heard popin sounds and now i have no power
Apr 24, 2009 | Optoma HD65 DLP Projector
Optoma ep 706, lamp lights on,replaced lamp, still not working
moz-screenshot.jpgmoz-screenshot-1.jpghello,
This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
Bye.
anytony2004@yahoo.com
Aniekeme Anthony.
I
Jan 21, 2009 | Optoma EP706 DLP Projector
Got mine to turn on even without the color wheel. The trick is to place the new lamp in and screw down all screws. When replacing the cover besure that the protruding plastic enters on the correct side of the wire switch in side. Tighten the lamp cover screws and do CPR on the center of the cover to ensure the wire switch has moved to the on position below the cover. Plug in the power to see if it works. If not, do CPR with your thumbs on the center of the lamp cover again. Usually this will fix it.
Oct 31, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
