Question about Kyocera Copystar CS-1820 Black and White Copier
KM-1820 Prints too dark
When using the print function from a computer, then page has extra toner. It looks like the exposure is set too high. I can not find a setting to change the printer not the copier.
    President:
  • Kyocera Master
  • 990 Answers
Dear sir; As you descript, seem like your machine have over toner, Here have one mode you can try to simulated;
1, press and hold them down "start", "#", "enter" these three keys.
2, enter 144, press enter, there is a single digit display on screen.
3, setting the number on 0,
give them a try ,see what's happen and let me know the result.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 18, 2008
  • Everett Lin Dec 23, 2008
    Hello sir; Is this simulation help? if yes, please give me a rating, if not please let me know, thank you.
DIRTY COPIES BOTH SIDE OF PAPER
don't always believe what they say. just because its "supposed to " last a certain amount of time, doesn't mean it will. Once you get the insides dirty, its hard to get them straight again. Sometimes there is build up on the printer head from a leaky cartridge. I'm just guessing cause I had a similar brand that was brand new act up on me and because I was printing bold it started rolling the paper. I put it on economy printing to save toner and after a few runs, it cleared up. plus using a watermark helped but don't think that will help you in your situation.
Sometimes when I get a streak on one side its from light coming in from somewhere and it thinks its part of the image and prints it. If you make sure that your material is flat and not allowing light to come in or its firmly against the glass it might help.
Feb 20, 2014 | Kyocera Km-1820 Copier Fax Machine
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Dec 08, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
what is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Oct 05, 2008 | Minolta Office Equipment & Supplies
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
Shadow/duplicate printing
in computer goto printer setting mode and uncheck option
toner saving mode and check out for dark or light effect
Jan 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
136 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
