Question about Whirlpool GSW9800PW Washer
    Problem Solver:
  • 12 Answers
Need to replace lid switch.
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Dec 24, 2008
Washer wont fill but work fine through all other cycles.
My washer will not fill with water to the level that I set it on the panel.
Dec 14, 2013 | GE WBSE2090A Top Load Washer
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Error code e01 f08
Knowed as F8 E1 error code...
This code indicates there maybe a problem with the water supply to the washer. Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; you can find them by entering your model number in the search tool below.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent? Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
To remove the error display, press Power once. Then press Power again to restart the washer. If pressing Power does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
* On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
* If the error remains on the display, and all of the other conditions above have been checked, call for service.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 26, 2011 | Whirlpool WFW94HEX Washer
It won't begin the cycle. The counter works but
Door not latcning or faulity door switch. fauilty timer or motor. dosent fill float switch faulity or stuck open or clogged inlet valve.
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Washer filled up for the rinse cycle then stopped won't do anything now. checked the outlet and have power there. Washer still full of water.
first of all you need to empty this washer by pulling the drainage pipe out of the waste pipe at the back then place a bowl on the floor and place the pipe into the bowl until all the water stops,when bowl gets to full then lift pipe higher than the washer to stop water coming out,once empty renew the carbon bushes on the motor as this will be the problem.
Jul 06, 2009 | Washing Machines
Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 80 Series Heavy Duty Super Capacity Plus
that is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does not begin cycle
The buzzing noise sounds like the water valve calling for water.. check your water suppy to washer... dont sound like its getting any water or theres a blockage kinked hose ect.
Sep 02, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool GSW9800PW Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
