Question about KDS Visual Sensations 190 (White) 19 in.CRT Conventional Monitor
Monitor works on G4 but not Macpro
I have 2 identical KDS 19in monitors. They have both worked for years on a Mac G4 system. Recently upgraded to MacPro desktop. One monitor works fine. The other wont boot & crashes the system. I've checked all ports ,extensions, and cables, which are working fine. The monitor still works with the old G4 when I reconnect it.
SOURCE: KDS radius 17"LCD RAD-7C shuts off during boot and won't come back on (mostly)
I am having the same problem and this seems to be very similar to the problem these users are having but that is a different screen. So I was hoping someone would have more info on this specific monitor. I am seeing no budging capacitors on my boards.
Posted on Jun 12, 2007
SOURCE: The monitor goes blank after just a few seconds or sometimes works for hours.
My monitor worked one day - gone the next. Nothing on the screen except a bright green glow. No tech support for this problem. They want $70. just to look at it.
Posted on Mar 06, 2008
  • 8 Answers
SOURCE: KDS K717s 17" LCD Monitor
This is a common problem across many monitors, unfortunately. The problem stems from one of two things, typically.
Itis either the Power Inverter board (Inverter Mirage Electronics AD-1700Rev:F 200-000-170DTL1 VERSION:A) or a weak or dying backlight.
Ifyour monitor comes on for a few seconds then you can test the backlight byusing the controls to get into the backlight brightnes settings on theOSD and turning it WAY down.
If that doesn't work or if it won't come on at all then it islikely bad capacitors on the Power board mentioned above. If you feeladventurous and know how to solder then you might be able to fix thisyourself. You need to be careful however because you are dealing withhigh voltage in there and capacitors CAN hold a charge long after youhave unplugged the unit. You can read more about this power board aswell as how to replace the bad caps HERE.
Ifthat's not for you then I would recommend taking it to a local TV shopfor them to fix. The parts shouldn't be more than $20, but labor can beexpensive.
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Posted on Feb 16, 2009
  • 1684 Answers
SOURCE: My monitor stays on for 6 seconds
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
I need a driver for kds 2200w product # k22mdwb windows xp
there should be 2 wires going to the monitor power and signal .if your system can't see it it will not work ever
Aug 02, 2015 | KDS Computers & Internet
Why won't my K917s 900p monitor show my MAC Pro screen?
get rid of the new installation it is not compatible with your system
Apr 29, 2014 | KDS Computers & Internet
I have a brand new Macpro that my teens got for xmas, used it 1 day and the screen stays black, I can hear the fan but the screen shows nothing.
When you press the power button do you hear a chime. If you do your monitor cable is probably loose. If you do not hear a chime there is a physical problem with the computer and you should make and appointment with the apple store to have it checked out.
Jan 29, 2011 | Apple PowerBook G4 Mac Notebook
I have a question can i instal two pc moniters to an apple G4 dektop?
I have 2 monitor. 1.) Apple Monitor 2.) dell monitr You just need the Graphic card added . i got mine from a old Mac
Oct 12, 2010 | Apple eMac G4 Desktop
My 15" Powerbook G4 screen is half blank - it sometimes shows lines or has some blank spots but it's always gone away. This time it seems stuck. What to do?
Hi There,
If you can get your laptop connected to an external monitor it will do the main troubleshooting for you. With it connected and set to display on the monitor, the 2 options below are pretty solid;
1. If the monitor shows your nomal desktop display without any distortion or lines, etc, then you can be fairly certain your LCD screen panel on the laptop is just wearing out.
2. If the monitor shows exactly what the laptop does, i.e., same exact problems, then it means that the Video chip on the logic board is about to fail and you'll have todecide whether to repair or upgrade to a newer machine.
I wish you the best.
Sep 08, 2010 | Apple PowerBook G4 Mac Notebook
Monitor won't "sync"
Analysis procedure on this one is straightforward, though equipment intensive.
1) Put a different display on the Mac and see if it works better.
2) Put a different computer on the display and see if it works better.
Until you do this, we don't even know what component is at fault. Once we do, you can proceed from there.
Aug 18, 2009 | Apple eMac G4 Desktop
No monitor works on my G4 Power Mac
If no monitor works on your Mac, but the machine is booting, the only assumption I can draw from this is a faulty display card.
Try another display card and see if this helps.
Regards,
Graemevm
Apr 19, 2009 | Apple eMac G4 Desktop
Monitor does not want to come on
Twelve years is a lifetime for a monitor.
May 15, 2017 | KDS 17S 17" Monitor
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Grey screen
First, you need to eliminate the video card or the Kogi as the problem, which is quite easy to do by testing a known working monitor on the Matrox card.
Jan 26, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
KDS Visual Sensations 190 (White) 19 in.CRT Conventional Monitor Logo
41 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
