Question about Sony Handycam DCR-TRV250 Digital Camcorder
My sony camcorder flahses C31:22
Recently my sony camocorder keeps flashing the code C31:22 and a little arrow in the middle of the screen. It stops only after i remove tape from the camera. Please advice
  • 1 more comment
  • rcblade Nov 25, 2007
    Having the same problem exactly as you have already stated!!!!. If you have a solution please help?
  • otherstuff Dec 29, 2007
    Yup same problem. Pressing the 'reset' button didn't help with or without a tape in it. Different tapes didn't seem to matter either.
  • soloyou Mar 04, 2009
    same issue
You guys were right! I banged on my DCR-TRV 280 Digital8 and  it's back working. Hallelujah!
Posted on Feb 26, 2009
    Problem Solver:
  • 10 Answers
If tapping does not help it might be a bad contact in a flat cable connecting the mechanics to the main controller. I had this problem on a Sony TRV120e (similar tot TRV125, TRV320 and others). Repair is a bit delicate, do not try this if you are not comfortable with repairs of fine electronics. Open the camera, remove the small flat cable situated on the bottom of the main controller and to the lens side of the camera. Clean the contacts and put it back. Presto.
Posted on Apr 01, 2012
I just blew inside it. Presto.
Posted on Jun 18, 2008
FIX
Sounds crazy... smack it a few times. Found at:
http://www.pechorin.com/m/2004/11/16/FIX_for_Self_Diagnosis_C3122-226151-7.html
Whacked it 2 or 3 times on bottom and sides a bit harder than you might burp a baby. And darn it if it didn't work.
Posted on Dec 29, 2007
I tapted on the reset button and it was gon but don't ask me what it want to say it grtz. david
Posted on Dec 17, 2007
SOURCE:
I have a sony hdd handycam camocorder and i'm trying to upload photos from the camera to my laptop but I get a message on my screen saying "check the connected device" and my computer says no photos are...
try a different usb cable. mine did that, used different cable and now it works fine. also you could try reinstalling the usb utility from the installation disk that came with the camcorder.
Aug 31, 2010 | Sony DCR-SR47 Camcorder
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
C 31
The camcorder has detected an issue that may require a power reset. To POWER reset the Camcorder,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 06, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
My camera has never been dropped why isn't my flash working?
Hi jlapread
If your camera is giving you a `E91` error on screen it could be a faulty flash module and need replacing at a Sony Service Center. Contact your dealer for info.
But, before you do that try steps 1 and 2 below.
Here is some things you can try:
1. If it is only a setting you can select the `green` camera for auto shooting and then press the `UP arrow key until the flash sign is shown on the screen. The screen will also say `Flash On`. Take a picture to see if it works.
If not proceed to `2` below.
2. Press the `Menu` button.
First select the `Green` camera on the selection knob.
Scroll with the right arrow to the little toolbox picture.
Once in the setup menu scroll down to the toolbox picture with a 1 under neath.
Press the right arrow arrow and then scroll to the `Intialize` option.
Press the right button and select `OK`.
Press the middle button on the arrow selector.
Camera now wants to know if you are sure, select ok.
You will now have to enter the date again and setup any `Program` settings you might want on the camera.
Now take the camera into a dark room - as it is now on `Flash Auto` and test to see if the flash works.
If none of these helped you, you can take the camera to a repair agent and get it fixed. I have replaced numerous of the flash modules at approximately a quarter of the cost of the camera.
Hope this information helps you.
Good luck
Jan 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Blinking arrow and numbers, won't eject, play, rewind, fastforward
your camcorder must be broken. a specialist should work on that. go to your nearest technician to help you with. they have a tools for that. hope that helps!
CHARCOIS
Aug 08, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony Camcorder Mini DV tape doesn't go in
Have you cleaned the tape deck at all? That might work.
Jul 04, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Sony Handycam DCR-TRV250 Digital Camcorder Logo
409 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
