Question about Marvin Quartz Radiant Heater
Marvin 5460 heater not heating any longer
This heater is not heating any longer. can i repair it?
Buffalo12980
  • 625 Answers
SOURCE: Defective heater
i think you are stuck but if you look around maybe you can find a universal control for your heater.
Posted on Nov 04, 2007
SRF518
  • 232 Answers
SOURCE: the heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
Posted on Oct 14, 2009
  • 10 Answers
SOURCE: Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Posted on Jan 07, 2010
  • 1015 Answers
SOURCE: pluged in but not working only light comes on
I would guess that the element is burned out. As these are a relatively inexpensive item I would not waste a lot of time or effort trying to repair it. I hope this helps you. Thanks
Posted on Nov 29, 2010
rockmeister
  • 2047 Answers
SOURCE: I have model 5460 by
First if you do not have previous electrical experience with heaters refer to an expert otherwise you will spoil the unit more. The problem with your unit is the thermostat it is either not set for your temperature or it is faulty. The thermostat is that component of your unit which regulates if the unit bring out heat or cold. When the thermostat does not function as it should the unit regardless of the wattage. Mostly when a thermostat is faulty the unit is more like not on because the thermostat which is responsible for its functioning is partly out of order.
Best get an expert to check the thermostat connections or replace it completely.
Hope this solution has been helpful?
Posted on Feb 16, 2011
Broken power cord to marvin heater
Heater power cords should not be spliced or repaired.
Dec 11, 2013 | Marvin Heating & Cooling
Pluged in but not working only light comes on marvin 5460 radiant qaurts heater
Nov 29, 2010 | Marvin 7960 Utility Heater
I have a 5460 radiant heater . you turn it on and it works alittle while and shuts off .
So you want to know how I fixed my problem with my heater. If so I like to offer you my "Premium Fix it Plan" for just $19.99. WHAT A DEAL..
Dec 11, 2009 | Marvin W.B. 5460 Quartz Humidifier/Heater
The heating elements are burnt out. where can I
Oct 14, 2009 | Marvin Quartz Radiant Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Thermostat control knob
(937) 653-7131 is the phone number of W B Marvin, according to my Google search. They should be able to help you get a new knob.
Feb 29, 2008 | Marvin W.B. 5460 Quartz Humidifier/Heater
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Reddy heater repair part number book
Hi Heaterman,
All reddy should have a label on the heater with their phone contact information. Isuggest calling them and asking them to send you all documentation on your heater.
Nov 08, 2007 | Heating & Cooling
Defective heater
Oct 25, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Marvin Heating & Cooling Experts
Daniel Gasser
Level 1 Expert
Oloyede Monsuru
terry stevens
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
