Question about Powerline 200Watt DC to AC inverter (0900-35) Power Supply
When switch is turned on alarm sounds and there is no power
I have the model 0900-73 powerline ac to dc adaptor. When I hook it up the green light comes on. When I turn the power on, the red light comes on too and it doesn not provide power. Any suggestions?
  • Anonymous May 16, 2009
    when i flip the switch it beeps and flashes the red light repeatedly. is there something i can do to fix this or should I just go buy a new one?
  • 111 Answers
It could be a cmos battery boot it in bios and check for flagged components, if u do not find anything try it with another power supply as this could several different problems
Posted on Dec 19, 2008
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
0xc190003 HP b010
"Gondo" <nowingspaanspam@yahoo.com> wrote in message
news:fsv880din9khpu7e9p8olvrc8uj1u1uj3o@4ax.com...
> This has been an ongoing problem with this laptop, and now I can
> hardly get it to power up at all.
> First, the AC/DC power adaptor jack in the back is very loose and
the
> power is lost intermittently when you move the jack around on the
> receptacle.
> Once the green power light does come on, you press the power switch
> repeatedly to the left to turn the laptop on and nothing happens.
Only
> by the combination of wiggling the power adapter jack around while
> pushing the power button repeatedly can you maybe get lucky and get
it
> to start up.
> I was just wondering what else might be bad internally besides the
> power adaptor jack. Possibly the connection to the power switch or
the
> switch itself? The AC/DC adaptor was replaced recently, so I'm
pretty
> sure that isn't the problem.
> It appears it will need replacement parts, so I'm looking for
> recommendations on where to find the applicable parts online.
To Fix Your Hp Issue,In Case You Still Having Problem Then Follow Us For On : HP Support
Feb 26, 2013 | HEWLETT-PACKARD Hp Ac Adapter Power...
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
The orange charge light comes on but when I press to start computor nothing happens no green light, the orange light flickers a few times.....I have taken out hard drive and batteries afew time but nothing...
Charger faulty or Motherboard problem.
You can check the power supply of the charger by measuring the DC voltage at the DC jack with a multimeter set to DC volts (red probe on the inner of the jack, black probe on the outer of the jack, should measure 18-20 volts.
Also check the security of the jack in the DC port, make sure it is not loose
See if the Ac adaptor has a green led on it, flashing LED indicates power not being "used " by the laptop
Gut instinct with this being a compaq is that the fault lies in the motherboard
Jan 12, 2011 | Compaq Evo N610C Notebook
Monitor wont come on.green lite on the switching adaptor is off.Is the adaptor bad or monitor bad? How do I get a new adaptor?Model # WDS048120
The lamp on the power supply adapter should be on the minute it is plugged onto the AC outlet without the DC plug connected to the monitor, if it is not on then the AC adapter is bad, you can check the DC voltage with a digital meter. Post back so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | X2Gen MG19MY 19" LCD Monitor
The ac adaptor light is permanently red
Hook up the ac adaptor and make sure the other end is not plugged into the xbox 360. if its still red then your ac adaptor is bad. If its still green then plug the other end into the 360 and if it turns red then that means the mainboard inside the 360 is bad.
Jun 06, 2009 | Microsoft Xbox 360 Console
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
Powerline 200Watt DC to AC inverter (0900-35) Power Supply Logo
318 people viewed this question
Top Powerline Computers & Internet Experts
Chris Larocque
Ivan Young
Ivan Young
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
