Question about IBM ThinkPad T23 2647 Notebook
My IBM thinkpad T23 is in for repair for harddrive. require 2 passwords to access harddrive to retrieve my data...the type # 2647-4MU serial # 78BPKCC.
can you please help
  • IBM Master
  • 32,281 Answers
Sharon, you have a extremly difficult problem.
Why is the laptop in for repair, is the laptop faulty, how do you know the hard drive is faulty when you cannot start up the laptop?
It appears that you have or someone has set up a power on password and possibly a password protection on the hard drive.
If you hard drive is faulty it is highly unlikely that you cannot retrieve any data off your hard drive with or without the passwords.
IBM ThinkPads laptops store the Power On password on an EEPROM chip and removing the BIOS battery cannot clear this password. there are no backdoor passwords that you can use. The passwords are used to prevent unauthorized access to the laptop and its data.
If there isn't a password on the hard disk, and the hard disk is not faulty, you can remove the hard drive and connect it to a working computer to read and copy off your data. I suggest you connect your hard drive using a USB hard drive adapter and connecting it to a working computer's USB port.
IBM states that if you don't know the Power On password, therefore you cannot get into the BIOS to remove the password, and you need to replace the motherboard (this is not cheap).
There is a way to hack into the laptop, it required some electronic experience to build a reader device, dismantle the laptop, solder it to the EEPROM chip, connect the output to a working computer, run a reader program, locate the password from this data, unsolder the wires, put the laptop back together and boot up and enter the password.
For detailed information go to
I have successfully removed these passwords, it is a lot of work, and needs to be tackled by an experienced person.
Best of luck.
Posted on Dec 19, 2008
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Forgot my password to power on my ibm t23 what can i do ?
If a BIOS or HD lock password you are out of luck.
BIOS password means replacement of the system board. HD password requires replacement of the HD and reinstallation of all software on new drive.
This is a security feature so no one can steal laptops and try to use or sell it.
Feb 16, 2010 | IBM ThinkPad T23 Notebook
Internet wireless
Hi there.
You probably need the drivers for the wireless card, get all the drivers for your model laptop from IBM/Lenovo support here >>>>
Good luck and thanks for using FixYa!!
May 07, 2009 | IBM ThinkPad T23 2647 Notebook
Supervisor password
A Supervisor password protects the system information stored in the BIOS. The user must enter the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to change the system configuration. If the Supervisor password is forgotten there is no way to reset it to enter the BIOS configuration. Setting a Supervisor password automatically sets the master Hard drive password. The following is the icon that comes up in the upper left corner if a Supervisor password is set:
A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To regain access, the system will need to be serviced to have the system board and hard drive replaced. Proof of purchase is required, and this repair is not covered under the warranty.
Document id: MIGR-59377 Last modified: 2005-06-17 Copyright © 2009 IBM Corporation Copyright © Lenovo 2009, all rights reserved
Mar 25, 2009 | Lenovo ThinkPad R51
Can't unlock my ibm thinkpad t23
Your computer has been protected by a Power On password.
If you didn't set this password then ask the person who set the password on the computer.
This password is near impossible to crack, try various names, pets, kid's names, family names/places, street names etc. There are no back door passwords and the password is not stored in the BIOS and removing the BIOS battery won't erase the password.
The password is stored on an EEPROM chip and you need electronic knowledge to build an EEPROM reader, then pull your laptop apart, solder the reader to your laptop, connect the reader's connector to a working computer, and run a program to read the contents of the EEPROM, identify the password from the downloaded data, unsolder the reader, put the laptop back together, boot up and insert the password. You can now enter the BIOS and change the password or remove it.
For further info goto
The Power On password and the Hard drive password are designed to prevent unauthorized access to the laptop and the data that is stored on its hard drive.
Removing the hard drive from the protected laptop and inserting it into another laptop will not work, you still cannot access the data on the hard drive without the correct password.
Jan 22, 2009 | IBM ThinkPad T23 Notebook
I need ibm thinkpad t23 vga drive
Drivers for Vista are not available.
You can find all drivers for Windows XP{ and older clicking below:
IBM Thinkpad Driver Download models T22, T23
Direct link to Video driver below:
T23 Video driver, v12.90.90
Dec 22, 2008 | IBM ThinkPad T23 Notebook
Hard drive for ibm t23 /t30 are they interchangable?
Yes you can, the manual says they borh using 2,5 inch ide HDD'
Here is the manual to t23
And here is the manual for t30
Good luck to you
If you find my answer helpfull, dont forget to vote!
Dec 18, 2008 | IBM ThinkPad T23 2647 Notebook
Power-on password problem!
The power on password is stored on an EEPROM chip and removing the BIOS/CMOS battery won't help.
You need to read the EEPROM chip to get the password.
for solution to your problem (you need to construct an interface hardware and install two programs on a working computer)
Have fun
Dec 28, 2007 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
180 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
