Question about Microsoft Windows XP Professional
Downloaded a microsoft patch, system will not restart
I downloaded a patch from micosoft. When rebooting the computer will not reboot.in safe mode or last know configuration
How do I revert to anything other than a blue screen
    Problem Solver:
  • 9 Answers
1)Go in to safe mode
 2) try to get back your sys. using system restore point.
Posted on Dec 18, 2008
How do I get my nextbook tablet out of safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Nov 04, 2015 | Nextbook Tablets & eReaders
Windows xp contineous reboot after installation of Avira antivirus
You might have other issues other than antivirus ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then uninstall Anvira then you might restart to see if the problem is resolved if not start in safe mode again
Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps
Jan 21, 2013 | Computers & Internet
Remove my pc virus
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials
Hope this helps.
Dec 30, 2012 | AVG Anti-Virus & Firewall 9.0 (2...
Remove virus of my computer
Enable VGA mode
Reboot
Dec 13, 2012 | Computers & Internet
Downloaded Windows XP Update SP 3. Now system
When you installed SP3 it was also placed into Add/Remove programs, (In control panel). Boot the system and enter safe mode. Uninstall SP3.
See also Microsofts instructions on how to remove SP3; http://support.microsoft.com/kb/950249
Did you find this helpful
Mike
May 21, 2010 | Microsoft Windows XP Home Edition
Is there a safe way to exit safe mode? Currently I am pushing the power button.
you can exit safe mode by restarting the computer
start->shutdown-restart however if the computer reboots only in safe mode you can check one option in system configuration utlity
start-run-msconfig-boot.ini..make sure safeboot is not selected.
http://www.ikarmatech.com
cheers.
Sep 11, 2009 | Microsoft Computers & Internet
Help reboot with no cd.
Boot with F8, choose "Safe Mode with Command Prompt" and follow:
http://support.microsoft.com/kb/304449
to access System Restore via Safe Mode to choose an image of your system at an earlier (and safer) time. Good luck.
Jun 13, 2009 | Acer Aspire 3690-2196 Notebook
Restarts computer in loop at 5-8 minutes of boot
Please try install XP SP3 in safe mode. Then check whether you have the latest Graphics Card Driver. It seems like some driver issue as it reboots only in Normal mode. Since safe mode runs on minimalset of hardware drivers.
Secondly, there may be a corrupt file that caused reboot. Spend a night and schedule bad sector check - Right click on system drive, Tools tab, Error Checking -> Check Now, tick both boxes then Start. It will schedule scan on next reboot. Then reboot to confirm it starts checking HD.
Apr 24, 2009 | Microsoft Windows XP Professional With...
Pinnacle Studio Plus version 10 Keeps Crashing
If you are getting any type of error message or warning message (except a fatal crash message), then , click here to see the FAQ titled "Studio Launch error/warning messages" to resolve these issues. For a fatal crash or any type of lockup/freezing while launching, continue with this FAQ, below.
If Studio was launching for some period of time and then it stopped launching, it is best to try to determine what changes have been made to the computer recently and undo the changes to see if it has an affect on the problem. Here's a short list of what could affect Studio's ability to launch:
  • A Studio patch was applied but it didn't install properly
  • The graphics driver was updated
  • Hardware was installed
We recommend using Windows XP System Restore. You can obtain more information on how System Restore works from the Microsoft web site at:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Troubleshooting steps for Studio hangs or crashing while launching (starting)
1. RESTART THE COMPUTER. Try restarting the computer
2. WAIT A FEW MINUTES: If Studio still won't launch, wait a few minutes to let it finish launching. We have noticed on some computers that it may take a little while for Studio to completely launch. Studio 10 users click here to see the FAQ on this.
3. LATEST VERSION OF STUDIO. There was a launch problems in previous versions of Studio 10 that are now fixed in the latest version. When troubleshooting any problem, it is always best to be on the latest version of the software.
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
If you have Studio version 10, download the latest version here .
Note: Studio 11 patches will only patch a previous install of Studio 11. Studio 10 patches will only patch a previous install of Studio 10. Etc.
If you have an older version of Studio (Studio 9 or 10, etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
4. SAFE MODE: Try launching Studio in Safe mode. In Safe mode, many device drivers and applications do not load. If Studio will launch in safe mode, then the issue is most likely a configuration problem with your computer. NOTE: We do not recommend using Studio in Safe Mode. This step is for testing purposes only. To start in Safe mode:
  • Shut down the computer
  • When you turn it back on, tap the F8 key every couple seconds until a menu pops up. (If the XP splash screen appears, the F8 keys was pressed too late so restart the computer and try this step again)
  • On the menu, choose Safe Mode, and then press the Enter key
  • Launch Studio
If you need help starting in Safe mode, you can click here to get information on Microsoft's web site
If Studio won't launch in Safe mode, then Studio many not be installed properly or the install may be corrupt. We recommend uninstalling and reinstalling Studio.
Click here to see the FAQ on how to uninstall, then reinstall Studio 10.
Oct 22, 2008 | Pinnacle Computers & Internet
Keyboard locks on Notebook
You should try downloading KEYBOARD Driver. TouchPad refers to MOUSE.
Sahaja Yoga is the Mahaa Yoga and is the Only Solution to all the Problems of World.
Apr 02, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
